Port Mach Hash Failed
jakirbasha69
I have a cisco sg350x 24 port with 10gig uplinks running as as small scale isp distribution switch
 my network scenario is i have 3 different isp routers connected to 1 gig ports
remaining were used as downlinks. I am getting this error "%2SWMACTBL-N-PORTMACHASHFAILED: Port gi1/0/24 ,MAC 7c:a9:6b:73:e3:c2 : Cannot be added to the FDB (Hash Table Collision)" frequently. every now and then with different mac address. switch has approx 330 active vlans.  i couln't find any hardware loop or soft loop in my network.
any help would be much appreciated.
the number of drop events when compared to total packets received leads to a low drop probability that should not be an issue
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello @jakirbasasha69,
verify if the same MAC address is learned on another VLAN on another port at the same time.
We have seen a similar issue on recent IOS switch C3560 with IOS XE 16.9.5 in a customer network.
We have found that this case same MAC address learned on different VLANs on different ports caused log messages similar to yours.
However,
This looks like to be an high number for a device like yours that is intended for small business not ISP level.
How many MAC addresses are learned ?
Hope to help
Giuseppe
Approx 2400 to 2500 mac address has been learning.
And I have around 1500 total clients distributed from the switch with fiber
and wl connectivity.
And I am also getting drop events on multiple ports
Ss is attached for reference
Hope to help
Giuseppe
same mac learned on two different port
A que te réferis que se aprende?
