01-16-2025 08:38 AM
When you set a port mirror . Do the port need to be next to each other ? Also if one port is already active You can't mirror it. I would have two ports empty and set the mirror.
Thank you for any help,
01-16-2025 08:58 AM
There is no requirement for source and destination mirror ports physical proximity, beyond they must be in the same switch or stack.
https://documentation.meraki.com/MS/Monitoring_and_Reporting/Packet_Captures_and_Port_Mirroring_on_the_MS_Switch
01-17-2025 08:36 AM
It looks as though MS17 introduces RSPAN:
01-17-2025 02:48 AM
On a classic MS switch you can choose any other port on the same switch as destination port (except stacking ports of course).
On Catalyst based switch at the very least you will be able to send captures to different switches too.
04-10-2025 06:57 AM
Yes! If switches are not stacked!
No! If Switches are stacked!
