Port mirroring over 2 switches (to the VM over the trunk)
EvaldasOu
Level 4
Level 4
Hello guys.
There is a problem. I want to use port mirroring feature and get all the traffic that is sent to the Client 1. The copy of this traffic should reach  Client 2 ( Virtual machine on the Physical server).
Sorry for misunderstanding:
As I know we can use physical interface as a destination interface, but not the VLAN.  ( But I need to use just a VLAN as a destination , because there is other virtual machines, connected with the same trunk port ( on different VLANs).
Can you suggest how I should configure these switches to solve this problem?
14 Replies 14
Ivan Shirshin
You need RSPAN or ERSPAN sessions (depends on L2 or L3 setup) configured on SW1 (source) and SW2 (destination):
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/span.pdf
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml#topic1-1
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
but if I have just two 2950 switches?  Not Cat 6500?
Do you want to say that this is possible for SW2 to mirror traffic for the specific VLAN (where Client 2 is) ?
You did not specify in first port which switches you have :-)
For 2950 the RSPAN configuration is described in this guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_19_ea1/configuration/guide/swspan.html#wp1081130
Did you mean vlan as source in your question?.. You said destination cannot be vlan.
Actually, for RSPAN it is remote vlan set in the command:
     monitor session session_number destination remote vlan vlan-id reflector-port interface
Then, on SW2 you specify which physical interface this traffic is going to (connected to Client 2).
But valid source interfaces include only physical interfaces and port-channel logical interfaces, not vlans. So you will have to mirror the physical interfaces on SW 1 to Client 1 (set as source) with RSPAN to SW2 with connected client 2 (see configuration doe RSPAN destination sessions).
Overall this mirroing of traffic can be done with RSPAN.
Kind Regards,
Ivan
Kind Regards,
Ivan
Thank you Ivan.
I will try to use RSPAN configuration.
Welcome! Let me know if you encounter any issues configuring it.
Kind Regards,
Ivan
Please take a look at the first question again Ivan. I edited it a bit.
Since a destination port is a trunk, it should pass tagged traffic to the connected destination host. So if your source host Client 1 is sending tagged traffic to SW1, then I think destination host would receive the traffic with same tag and put it into corresponding VLAN/VM.
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan!
In this situation I'm interested just in traffic, which is going from WAN to the Client 1. ( We don't care about outbound traffic which is going from Client 1.)
What is the confuiguration of the ports on SW1 towards WAN and towards Client? Are any of them  trunks?
Kind Regards,
Ivan
Configuration of these ports is not a trunks. It is just an access ports.  (SW1)
I have rechecked 2950 switch RSPAN behavior with tagged traffic and all packets  appear on the destination port as untagged, as long as you don't add "encap dot1q" parameter in destination session command. So you could either:
1. specify the native vlan on a trunk to have this untagged traffic sent in the vlan corresponding to your VM:
     switchport trunk native vlan vlan-id
2. or set up "encap dot1q" on SW2:
     monitor session 1 destination interface encap dot1q
Changes to destination port should be made before configuring the destination monitor session.
By the way, note that regular traffic won't be sent on this trunk anymore and other VM machines won't be able to communicate with through this interface because when destination port is active, incoming traffic is disabled.  The port does not transmit any traffic except that required for the SPAN  session.
Kind Regards,
Ivan
Kind Regards,
Ivan
Thank you very much Ivan.
I was looking for this solution.
And that's ok, I don't need any regular traffic on that trunk link ( on the trunk link between SW1 and SW2 , but what about the trunk link between SW2 and the server? Can virtual machines use this trunk?)
I will try to implement this today
Thank you!
Welcome again! :-)
Kind Regards,
Ivan
Ok. I updated the picture :
There is a trunk between SW1 and SW2. Just one VLAN is allowed, VLAN 999 ( remote - span VLAN ).
My configuration looks like this:
On SW1 :
monitor session 1 source interface Fa0/21 tx
monitor session 1 destination remote vlan 999 reflector-port Fa0/20
On SW2:
monitor session 1 destination interface Fa0/24 encapsulation dot1q ingress vlan 999
monitor session 1 source remote vlan 999
Virtual machine is in VLAN 999.
The problem is, when I just apply configuration on SW1 , interface Fa0/23 on SW2 goes down. ( Status and protocol is down/down).
Then on SW1 interface Fa0/20 is with status up/down . We can see this if these ports are configured as access ports not  as  a trunk ports too.
I can't see any sniffed traffic on Virtual Machine in VLAN 999 :/
