port mirroring
TECH-JEFF
Hi, just want to ask how do you verify if 2 ports were successfully configured as port mirroring?
We've setup 2 ports in our 3750 L3 switch by typing in the command below:
monitor session 1 source interface gigabitethernet Gi0/16
monitor session 1 source interface gigabitethernet Gi0/17
So how do we verify if both ports aree doing mirror already?
The reason why we did this mirroring is because we purchased a network management Sangfor. Where do we connected this? source? or destination?
Jeff
Jefferson Co
johnlloyd_13
Level 9
Level 9
hi,
use show monitor session 1 to verify port mirroring.
you can use the both keyword if you want to SPAN ingress and egress traffic:
monitor session 1 source interface gigabitethernet Gi0/16 both
monitor session 1 source interface gigabitethernet Gi0/17 both
you should have a SPAN destination port using the command monitor session 1 destination interface g0/x. this is where your NMS (sangfor) should be connected.
johnlloyd_13
Level 9
Level 9
hi,
actually I've saw that command in an article but after I type in that command it shows;
Type : Local Session
Source Ports :
Both : Gi1/0/16
Destination Ports : Gi1/0/17
Encapsulation : Native
Ingress : Disabled
Do I need to do additional commands to enable ingress?
The command I type in to configure both ports are:
monitor session 1 source interface Gi1/0/16
monitor session 1 destination interface Gi1/0/17
Am I still missing something?
Jeff
Jefferson Co
hi,
this output is normal. the 'both' keyword is also the default, so SPAN replicates both ingress and egress traffic.
the source and destination SPAN config is all you need.
