Port naming structure for C9200L-48T-4G-E
knaik99
Can we have Port naming structure for C9200L-48T-4G-E i.e. is it like gi0/1 or gi1/1/1 like that
Giuseppe Larosa
Hello knaik99,
stackable switches use the gi1/0/x convention so that in case of forming a stack can become gi m/0/x where m is the switch number on the stack.
I would expect C9200L-48T-4G-E to follow this naming convention
ports on the uplink module should be named gi1/1/y.
This is another reason to have three numbers to support ports in uplink modules.
Edit:
C9200L is stackable if adding the stack kit see table 4 of the datasheet
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html?dtid=osscdc000283
So it should use the three numbers numbering convention.
Hope to help
Giuseppe
Yes i can confirm what Giuseppe has stated , my 9ks both 92s and 93s use the 3 x format g1/0/1 , as default even when standalone and not stacked
extract from brand new switch below before configuration
Vlan1 unassigned YES unset administratively down down
GigabitEthernet0/0 unassigned YES unset administratively down down
GigabitEthernet1/0/1 unassigned YES unset down down
GigabitEthernet1/0/2 unassigned YES unset down down
GigabitEthernet1/0/3 unassigned YES unset down down
GigabitEthernet1/0/4 unassigned YES unset down down
GigabitEthernet1/0/5 unassigned YES unset down down
GigabitEthernet1/0/6 unassigned YES unset down down
GigabitEthernet1/0/7 unassigned YES unset down down
