ā04-03-2013 05:25 PM - edited ā03-07-2019 12:37 PM
Hi Guys,
Can someone show me blank configuration for WS-C4500X-16SFP+ (Catalyst 4500-X 16 TenGig Fixed ports switch).
I would like to know how the port numbering is done (i.e. TenGig1/0/X or TenGig1/X or just Eth1/0/X ? )
Thanks in advance.
Cheers.
ā04-03-2013 10:33 PM
Hello, on the 4500 I've seen interface TenGig 1/1 and these documents below suggest that they follow this method.http://www.cisco.com/en/US/docs/switches/lan/catalyst4500x/installation/notes/OL_24795.htmlhttp://www.cisco.com/en/US/docs/switches/lan/catalyst4500/15.1.2/XE_340/command/reference/int_sess.html#wp2100277However, if you are 'stacking' using VSS then you will need to specify the switch number, slot number and then port number.I.e. interface TenGig 1/1/1Will be on switch 1, slot 1, port 1Hope this helpsSent from Cisco Technical Support iPhone App
Log in to Community
