Port numbering sequence on C9300L-24T-4G-E
david-mullins
We use C9300L-24T-4G-E switches in some of our equipment. The CAD file I downloaded for our schematics list the port numbers as top row 1-6, 13-18, then bottom 7-12, 19-24. However, other switches list the port numbers as top 1,3,5,-11, 13,15,17,-23, and then bottom 2,4,6-12, 14,16,18-24. The front panel is not helpful as it only shows 1 up and 12 down. Both numbering sequences start and end this way.
Can anyone please confirm which way they number, please?
I've worked with plenty c9300, and all have been with odd numbers in top row and even numbers below.
And the picture also indicates with.
I'm guessing that there's something off with the CAD file you found?
david-mullins
Thank you, sir!
