Port problems
mikerocom1
I have a 2851 and a 3750. I have several IP cameras. I can see them inside my network just fine. However i cannot view my server remotely. I am using Blue Iris software. The app connects over port 81. I cannot connect through the app. When i go to the port scanner sites almost all are blocked.
Any ideas?
Router:
mikerorouter#sho run
Building configuration...
Current configuration : 2342 bytes
version 12.4
hostname mikerorouter
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging console
enable secret 5 $1$WC5M$b2bgySF8XI.MqeufJzi2O/
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.10.17.1
ip dhcp excluded-address 10.10.17.2
ip dhcp excluded-address 10.10.17.3
ip dhcp excluded-address 10.10.17.4
ip dhcp excluded-address 10.10.17.5
ip dhcp pool mikero
   import all
   network 10.10.17.0 255.255.255.0
   default-router 10.10.17.1
   dns-server 68.105.28.12 68.105.29.12 68.105.28.11
ip dhcp pool mikero_guest
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
ip domain name mikero.com
no ipv6 cef
voice-card 0
username admin secret 5 $1$snHZ$/D6wf/iVK7ii6js.RloA80
archive
 log config
  hidekeys
ip ssh version 2
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN
 no ip address
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 10.10.17.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 10.12.15.1 255.255.255.240
 ip nat inside
interface GigabitEthernet0/1.30
 encapsulation dot1Q 30
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
no ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
access-list 101 permit ip 10.10.17.0 0.0.0.255 any
access-list 102 permit ip 10.12.15.0 0.0.0.255 any
access-list 103 permit ip 10.10.10.0 0.0.0.255 any
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
line con 0
line aux 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
scheduler allocate 20000 1000
end
Switch:
mikeroswitch#sho run
Current configuration : 4747 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname mikeroswitch
no logging console
enable secret 5 $1$q48p$GHvmx5zju53WBx/7UncGD.
username admin secret 5 $1$2dnq$aA2/XzzIatORrobHFoYzc0
no aaa new-model
switch 1 provision ws-c3750-48p
ip subnet-zero
ip domain-name mikero.com
ip ssh version 2
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
 shutdown
interface FastEthernet1/0/2
 description DESKTOP MIKERO
 switchport access vlan 10
 switchport mode access
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
 switchport access vlan 20
interface FastEthernet1/0/18
interface FastEthernet1/0/19
 shutdown
interface FastEthernet1/0/20
 shutdown
interface FastEthernet1/0/21
 shutdown
interface FastEthernet1/0/22
 shutdown
interface FastEthernet1/0/23
 shutdown
interface FastEthernet1/0/24
 shutdown
interface FastEthernet1/0/25
 shutdown
interface FastEthernet1/0/26
 shutdown
interface FastEthernet1/0/27
 shutdown
interface FastEthernet1/0/28
 shutdown
interface FastEthernet1/0/29
 shutdown
interface FastEthernet1/0/30
 shutdown
interface FastEthernet1/0/31
 shutdown
interface FastEthernet1/0/32
interface FastEthernet1/0/33
 shutdown
interface FastEthernet1/0/34
 shutdown
interface FastEthernet1/0/35
 shutdown
interface FastEthernet1/0/36
 shutdown
interface FastEthernet1/0/37
 shutdown
interface FastEthernet1/0/38
 shutdown
interface FastEthernet1/0/39
 shutdown
interface FastEthernet1/0/40
 shutdown
interface FastEthernet1/0/41
 shutdown
interface FastEthernet1/0/42
 shutdown
interface FastEthernet1/0/43
 shutdown
interface FastEthernet1/0/44
 shutdown
interface FastEthernet1/0/45
 shutdown
interface FastEthernet1/0/46
 shutdown
interface FastEthernet1/0/47
 shutdown
interface FastEthernet1/0/48
 switchport access vlan 30
 shutdown
interface GigabitEthernet1/0/1
 description UPLINK
 switchport mode trunk
interface GigabitEthernet1/0/2
 shutdown
interface GigabitEthernet1/0/3
 description WAP
interface GigabitEthernet1/0/4
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 description MIKERO
 ip address 10.10.17.2 255.255.255.0
interface Vlan20
 description CAMERAS
 ip address 10.12.15.2 255.255.255.240
interface Vlan30
 description MIKERO_GUEST
 ip address 10.10.10.2 255.255.255.0
ip default-gateway 10.10.17.1
ip classless
ip http server
control-plane
line con 0
 speed 115200
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
Peter Paluch
I believe I see a couple of issues with the configuration of your router.
  1. Your default route on the router is currently configured as
    This is a very dangerous way of configuring a default route. It causes your router to rely on the ProxyARP functionality on your ISPs router so if the ISP ever decides to deactivate the ProxyARP, your default route will simply stop working. In addition, this configuration forces your router to issue an ARP request for each and every destination IP address your Internet-bound packets go to. This inevitably results into huge ARP traffic and excessively long ARP table (just try running show ip arp on your router - I am fairly sure you are going to have tens, if not hundreds entries for public IP addresses listed, all pointing to the same MAC address of your ISP's router). We have had another issue here on this very forum where someone had the default route configured the same way you have, and his router ended up reloading every now and then because the ARP cache grew so large that the router simply ran out of memory.
    Because your Gi0/0 uses DHCP to obtain its own IP address, you do not actually need to configure any default route manually. This will be assigned to your router automatically. Therefore, I strongly suggest removing your current static default route entirely from the configuration. Alternatively, you could enter your default route statically but tell the router that it is going to be obtained from DHCP (just paste the commands below into your config):
    no ip route 0.0.0.0 0.0.0.0 Gi0/0
    ip route 0.0.0.0 0.0.0.0 Gi0/0 dhcp
  2. Your ACL that is used for NAT purposes is not right. You have actually created three distinct and independent ACLs with numbers 101, 102 and 103, each of them having just a single entry. Your ip nat inside source command refers to ACL 101 which in turn references the IP network 10.10.17.0/24 only. This means that all your other networks are unable to access Internet because they are not NATted. Correctly, you should create a single ACL that has a single number and three entries, one for each of your internal networks (just paste the commands below into your config):
    access-list 101 permit ip 10.12.15.0 0.0.0.255 any
    access-list 101 permit ip 10.10.10.0 0.0.0.255 any
    no access-list 102
    no access-list 103
  3. If I understand you correctly, you are saying you want to reach an internal server from outside, using TCP port 81 as the destination. Is that correct? The problem I see currently is that your Gi0/0 interface is assigned its IP address via DHCP, and unless your ISP makes sure that you always get the same stable IP address, it is going to be a guesswork to know your outside IP address so that you can connect to it. Nevertheless, what you want to have is a static mapping between the outside TCP port 81 and the particular internal IP address and its port 81. Currently, there is no such mapping created. Without knowing your precise outside IP address, you can only configure this mapping using the following command:
    ip nat inside source static tcp A.A.A.A 81 interface Gi0/0 81
    Replace A.A.A.A with the internal IP address where the internal server is running. This command should create a mapping between whatever outside IP address your Gi0/0 is currently using and the internal server at A.A.A.A port 81. Now it should theoretically be possible to connect to this IP address and port from outside.
    You have to keep in mind that your own ISP may be doing some kind of firewalling, preventing outside world from opening TCP sessions to you. Therefore, if the connection to the outside IP address and port 81 fails, it may be possible that the ISP is blocking it. There is no quick way to tell.
Best regards,
Peter
Peter Paluch
    no access-list 102
    no access-list 103
Best regards,
Peter
Thank you!! You solved a few issues for me. My internet has been running slow when connecting to new sites on each computer. The ARP issue would explain this. My Vlan 30 would not connect to the internet and the access list explains that. So thank you for that!
You also solved the port issue. I still cant access the server remotely but at least i know its not a port issue.
