port-security in packet tracer's 2960 switch
Mary Poppins
I try to learn by myself. I would like to try the port security in the packet tracer software. I added a pc with an IP address, a 2960 switch on the workbench, and I connected them with straight-through cable. The tutorial said:
-in the interface configure mode:
(config-if)>  switchport mode access
(config-if)>  switchport port-security mac-address 0001.1231.1234
but the last steps doesn't seem to work, because the cli shows:
Port-security not enabled on interface FastEthernet0/1.
I tried to find solution on the web, but I found that the above two lines should be enough to work the port-security feature. Could somebody help me?
Any advice welcome
thank you
Mary Poppins
I'm so sorry. I found I forget to enable it before the last line with the command:
bye
Mary,
Yes here is the procedure to enable the port-security:
Switch(config)#int f0/1
Switch(config-if)#switchport mode access  >>> First make this port as access port.
Switch(config-if)#switchport port-security   >>> Enable the port security.
Switch(config-if)#switchport port-security mac-address 000.1111.2222 >> configure the mac address.
regards
Inayath
*Plz rate the usefull post and mark the thread as answered if this solved your issue.
