12-10-2010 06:01 AM - edited 03-06-2019 02:28 PM
I have a UPS plugged into an fa1/0/48, an access port. This is the output from a show spanning-tree, see bold.
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 8192
Address 0015.2c03.1001
Cost 3004
Port 1 (GigabitEthernet1/0/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 49153 (priority 49152 sys-id-ext 1)
Address 0021.1ba4.1c80
Aging Time 300
UplinkFast enabled but inactive in rapid-pvst mode
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/1 Root FWD 3004 128.1 P2p
Gi1/0/2 Altn BLK 3004 128.2 P2p
Fa1/0/48 Desg FWD 3100 128.52 Edge Shr
My question is, why does the UPS port, fa1/0/48 show as shared when it is only one device? I thought it would say shared only if a switch or hub was connected to that port.
Thanks, Pat
Solved! Go to Solution.
12-10-2010 06:19 AM
12-10-2010 06:41 AM
Hello Pat, Alain,
Let me add a few words.
A shared link in STP means that this link may possibly interconnect several machines, not a single device. For example, a shared port connects to hubs or wireless access points that indeed create a shared link. This distinction is very important in particular for RSTP because the rapid convergence is supported only on point-to-point links (and edge ports).
However, the RSTP has no reliable way of knowing whether a port connects to a single neighboring device (the point-to-point type) or whether it connects to a shared segment (the shared type). Therefore, Cisco switches try to make an educated guess. If the port is working in half duplex, it is assumed to be connected to a hub (because hub always work in half-duplex mode only), and Cisco switch concludes that the port is connected to a shared link. If the port is working in full-duplex mode then it is assumed that it is connected to a single device and is by default considered as a point-to-point port type.
So the half duplex or a full duplex is used only as a starting indication of the port type but it is still only a guess. For example, wireless access points are equipped with full-duplex wired ports but they still create a shared link, so assuming the port type basing only on the duplex setting is not reliable in all cases. You can also see that your UPS is a single device and the link type is essentially point-to-point, yet the Cisco switch thinks that the link is shared.
To sum it up - the shared or point-to-point link type in RSTP is concerned with the actual link topology connected to a port, and the duplex mode is used to make an estimation what the topology actually is.
Best regards,
Peter
12-10-2010 06:15 AM
hi,
shr means half duplex.
regards.
12-10-2010 06:18 AM
so if a switch was connected that was full duplex, it would not show as shared on an access port?
12-10-2010 06:19 AM
yes you're right.
12-10-2010 06:35 AM
Thanks, man.
12-10-2010 06:41 AM
Hello Pat, Alain,
Best regards,
Peter
