port switch is not stable
Dhikra Marghli
Level 5
Level 5
problem port is not stable
 i have a switch 2960-X linked with WLC 1815i with inter gi/0/15
probleme : port switch : green ( 60 seconde ) then Off ==> i would port switch green stable  that allow WLC is green ?
what comand used to trouble switch 2960-X ???????
2 Accepted Solutions
I send you a file that contain all show output
i hope please to resolve port switch  that to be green stable
i send you a file about WLC
so what is solution
35 Replies 35
Mark Elsen
 - Configure the port with logging event link-status (too);  periodically check the switch-logs by issuing show logging. On the long run it is better to configure the switch and the wlc to forward events to a syslog sever. To  be more comfortable when analyzing events.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
i send you a file to show output
pease help me what i can do for this problem that i can allow PORT is led green stable and WLC is green stable
i wait a solution
thanks in advance
can you post below please see whats up with the interface if there any errors
show interface e GigabitEthernet1/0/15
sh run int g1/0/15
i send a file  that allow to show output
that interface is clean no issue could be on the far end connection
post thos command from the switch
show spanning-tree detail | inc ieee|occurr|from|is exec
Please post the WLC interface switch is connected too , show interface x/x
i send you a file
so what is solution for port switch !!
i send you a file
SO what is probleme and solution !!
i wait for this team to resolve this port
try and configure the port on your switch as a trunk:
interface GigabitEthernet1/0/15
switchport mode trunk
no resulat , same problem
so what i can used as command or as show ????,,
What is the management VLAN on the AP ? Make sure that is is set to the native VLAN when you configure a trunk on the switch:
Here is an example:
Interface GigabitEthernet1/0/15
switchport trunk native vlan 2
switchport trunk allowed vlan 2,10,20,30
the problem is remain i try all possiblite  but port switch green after off then green
