port switch is not stable
Dhikra Marghli
Level 5
Level 5
problem port is not stable
 i have a switch 2960-X linked with WLC 1815i with inter gi/0/15
probleme : port switch : green ( 60 seconde ) then Off ==> i would port switch green stable  that allow WLC is green ?
what comand used to trouble switch 2960-X ???????
35 Replies 35
Both sides of the configs in each port should be matching
can you post the show run of the port in the WLC side so we can see what way its setup , it should match the switch
We have the switch side g1/0/15
i send you a file about WLC
so what is solution
can give any solution about port switch with WLC ?????,
i don' recive any answer formy problem !!!
so what i can doing ??????,
Are you able to share you switch port configuration.
I take it your referring to the LED on the switch for the connected port or are you referring to the LED on the AP?
For your reference here is the Mobility Express Deployment Guide
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Isend you a file  that show all output
i hope give me a solution
thanks in advance
 this requires more information.  First of all, if you realy have a layer 2 switch you should not ping it. Unless you are ping the management IP address.
 Who is providing DHCP and who is your gateway?  Can you explain your topology better.  A simple draw may help .
-If I helped you somehow, please, rate it as useful.-
 this requires more information.  First of all, if you really have a layer 2 switch you should not ping it. Unless you are ping the management IP address.
I have a problem with port switch 2960 with green then off then green  conntected with WLC 1815I ( red clignote)
so i send you file output switch then WLC
o need a help that allow  port switch to be a green stable and led WLC is green also
so what command used to resolve this problem ???????,,
thanks in advance
WLC conntected only with switch layer 2
so i con't ^ping from PC to WLC and virs versa !!!
switch 2960 POE
Moblity express 1815i
probleme connection physical switch with ME 1815I!!! port switch gi 1/0/15
hay friend
you could be hitting a bug with old versions of mobility express
try to update to the latest version in 8.5.140
and see if it helps with the flapping issue
Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
-> the ME recieves a packet without vlan tag (vlan 0 = untagged) while it is configured to use vlan 1 tagged packets
- either configure the ME to accept untagged packets as belonging to vlan 1
- or configure the switchport to send all packet swith vlan tag
a trunk port transmits untagged packets for the native VLAN plus encapsulated, tagged, packets for multiple VLANs
-> set the native vlan on the ME facing switchport NOT to management vlan
   (e.g. set it to vlan 999 so packets for vlan 1 will be sent tagged).
i configured as you tell me but is the same probleme :
i give  you updat configuration in the switch 2960  and the show  of ME 1815
uilding configuration...
Current configuration : 157 bytes
interface GigabitEthernet1/0/15
switchport trunk native vlan 999
switchport trunk allowed vlan 1,999
switchport mode trunk
spanning-tree portfast
end
Welcome to the Cisco Mobility Express command line interface.
Only commands which are listed in the command reference guide for this release are supported.
http://www.cisco.com/c/en/us/support/wireless/mobility-express/products-command-reference-list.html
(Cisco Controller) >show ca  ap st  join stats ?
(Cisco Controller) >show ap join stats summary all
Number of APs.............................................. 2
Base Mac AP EthernetMac AP Name IP Address Status
28:ac:9e:e3:23:20 N A AP28AC.9E89.3DB8 1.1.1.23 Not Joined  ????????????
a0:93:51:17:94:00 N A AP780C.F0DB.2A90 1.1.1.22 Not Joined ??????????????
so then the message error : AP is not joind to ME :
then what can a solution because i have three day in same problem !!
please help me and give me what i can doing !!
end
