Port unreachable messages on 3550 switch
Kevin Melton
Level 2
Level 2
While working at a client site today, I was troubleshooting some ICMP connectivity for a network we have created.
I turned on 'debug ip icmp" on the 3550 switch int he middle, and was inundated with the following debug output:
Jan 25 11:01:14.641: ICMP: dst (172.16.1.7) port unreachable rcv from 172.16.1.5
Jan 25 11:01:14.649: ICMP: dst (172.16.1.7) port unreachable rcv from 172.16.1.5
Jan 25 11:01:14.653: ICMP: dst (172.16.1.7) port unreachable rcv from 172.16.1.5
This output fires several times a second, and based on how often it is firing, I am curious if it may be a culprit with respect to the fact that the client has indicated that they have some slow internet.
Should the next step be to look at the workstation at 172.16.1.5?  I do need to get this issue resolved.
Thanks in advance for any help.
Kevin
10 Replies 10
JohnTylerPearce
Level 7
Level 7
Does the workstation at 172.16.1.5 have local lan connectivity and internet connectivity or just one or the other?
Does this only happen with a source and dest of the two addresses that you posted of several source and destinations?
I'm assuming both hosts are on the same vlan?
John
The workstation at 172.16.1.5 does have lan connectivity, as well as internet connectivity.
I dont understand the question necessarily...  but i will try to explain.
The 3550 switch native vlan 1 has an IP address of 172.16.1.7, which is the gateway for all workstations in the vlan to get off of the subnet to any other network.  The workstation at 172.16.1.5 has a DG of 1.7, as do the 4 other workststations in that VLAN.
This 3550 switch is a DMZ switch.  There is an Outside perimeter FW at address 172.16.1.2 and an Inside Perimeter FW at address 172.16.1.3.
The 3550 switch is routing, and for Internet connectivity, has a 0/0 route to the OP FW at the 1.2 address.  He also has static routes for inside networks, which point to 1.3, in case the wkstations in the DMZ need to get to the inside networks that lie behind the IP FW at 1.3.
Yes they are on the same VLAN.
Does the 172.16.1.0 network has a /24 mask?
From what I can tell the 3550 switch is doing routing for VLAN1, which is also the DMZ switch, and the DG
of the DMZ switch is the Outside FW at 172.16.1.2? So are these firewall devices specific hardware or software?
How are the Firewalls connectd to the 3550? All these devices seem to be in the same VLAN? Sorry if I don't get
back to you for a little while as well, I gotta leave for a funeral shortly.
Yes
of the DMZ switch is the Outside FW at 172.16.1.2? Correct
So are these firewall devices specific hardware or software?  Cisco ASA's
How are the Firewalls connectd to the 3550? see below
tbhedge#sho int des
Interface                      Status         Protocol Description
Vl1                            up             up
Fa0/1                          up             up       NEW BHIASAOP INSIDE INTERFACE
Fa0/2                          up             up       DMZagent
Fa0/3                          up             up       BHIASAIP OUTSIDE Interface
Port f0/1 is the Outside FW Inside interface at adx 172.16.1.2
port f0/2 is the workstation at address 172.16.1.5 that is apparently sending the ICMP port unreachable
port f0/3 connects to the Inside FW Outside interface at adx 172.16.1.3
All these devices seem to be in the same VLAN?  They are. the address space is 172.16.1.0/24
is this paste from the 3550? What I find interesting is that the each interface os the ASA is basically its own zone. So by having the ASA have an Outside interface on network 172.16.1.0/24, and Inside interface on 172.16.1.0/24, and the DMZ has 172.16.1.0, I find very interesting.....
Can you paste a copy of 'show int ip brief' on the asa?
What are the security levels on the ASA for each interface? By default interfaces with the same security level cannot communicate by default.
They are two different ASA's.  If you read the host name, one is BHIASAIP.  The other is BHIASAOP.
The OP (Outside Perimeter) faces the Internet.  It is the Inside Interface on the Outside FW that connects to the 3500 (which is the DMZ switch).
The IP (Inside Perimeter) ASA faces the Inside Private Nets.  It is the Outside Interface of this box that connects to the 3550.
The address space in the DMZ is 172.16.1.0/24.  The OP Inside interface , the Mgmt interface of the 3550, several servers and a couple of other devices, as well as the IP Outside interface, are all in this address range.
The Outside Interface of the OP FW is in a public address space.  The Inside Interface of the Inside FW is in a private network range.
ebarticel
Level 4
Level 4
I think you should have the Inside and Outside interfaces on ASA set on differents subnets.
Hope this helps
Eugen
I see how your setup now. It appears the 3550 is connected to both the Inside Perimeter and Outside Permiter ASA, as well as connected to the DMZAgent. I'm hoping that the inside interface on the OP ASA is in the 172.16.1.0/24 network.
What is the inside and outside interface on the IP ASA? The reason I"m asking you this, is that, it appears that you may have the same network configured on multiple ASAs.
John
Thanks for all of your help with this.  I was able to resolve the issue simply by rebooting the workstation.  Once that was done, there were no more port unreachables being sent.
The Inside of the OP FW and the Outside of the IP FW are in the DMZ, as they should be, in address space 172.16.1.0/24.  The inside interface of the IP FW is in a private address space connecting to the client core.
Take Care and thanks again JTP
Kevin
Glad to hear you got it working Kevin. At first it almost sounded like you had one ASA with the same network configuration, and I was gunna say please show me how it actually accepted the command to do that lol. I see what you're doing now.
