Bridging Wireless and LAN
pmillerj
Community Member
I currently have a 2811 and a LAN setup via a sub-interface FA0/1.3 and using a HWIC-AP I have a sub-interface dot11radio 0/1.5.  I have them setup to work and surf the inet great, but I have recently been overly annoyed with the fact that the wifi cannot access windows shares on desktops and visa versa with the laptops.
The trick to make this happen is currently they are not on the same subnet.  I know the answer is bridging the interfaces but when I do this using the simple commands:
bridge 1 protocol ieee
interface x & y
bridge-group 1
Although what should be simple has failed (good thing I tftp'd my working config).  Here is my current configuration. Please let me know if there is a way to make this happen.
interface FastEthernet0/1.30
encapsulation dot1Q 30
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
no ip route-cache
interface Dot11Radio0/2/0
no ip address
ip nat inside
encryption vlan 50 mode ciphers aes-ccm tkip
broadcast-key vlan 50 change 30
ssid MillerNET
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0/2/0.50
encapsulation dot1Q 50
ip address 192.168.5.1 255.255.255.0
no ip proxy-arp
ip nat inside
As always thanks in advance!
Jeff Van Houten
Level 11
Level 11
Didnt see the global irb command you need. Also when you bridge you take the ip addresses off the interfaces and create a new bvi interface with the correct address.
Jeff Van Houten
Level 11
Level 11
I will be implementing this tonight and will test it.  Wish me luck
I believe that worked but I will be monitoring it for awhile.
Thanks for the quick fix
