Port/VLAN mirroring on CBS250-16T-2G
ivrodriguez
We have recently purchased a CBS250-16T-2G switch (the model SG200-18 that we were using is no longer available) which, according to the datasheet, should have support for up to 4 ports or 4 VLAN mirroring. However, we couldn't manage to configure the mirroring through the Web interface.
In the SG200-18 the port has to be configured in Forbidden mode of operation, but this options is not available in CBS250-16T-2G. Indeed a "mirroring" in the built-in help does not produce any result.
We upgraded the FW to 3.4.0.17 without success.
Does CBS250-16T-2G actually support mirroring? If so, how is it configured?
Best regards
 Ivan
@ivrodriguez
In fact, it is on the datasheet and there is video explain how to deploy. If you followed all the step and still no luck. then, you probably might have a faulty device in hand.
 https://www.cisco.com/c/en/us/products/collateral/switches/business-250-series-smart-switches/nb-06-bus250-smart-switch-ds-cte-en.html
https://www.youtube.com/watch?v=PSGHvFvw_UU
amikat
Please make sure you are at the "Advanced" mode (top right corner menu). You will find "mirroring" under the "Status and Statistics" > "SPAN".
Best regards,
Antonin
