PortChannel and trunk config for ESX
IPhoneRZ
hello,
Maybe someone could advice me what are the best practices for configuration of Port-channle and its members for connection to ESX host.
Now I have config as below:
int port-channel 1
 switchport mode trunk
 switchport nonegotiate
 swithport allowed vlan 10-20
int range gig 1/0/1-4
chanel-protocol lacp
chnnel-group 1 mode active
And Questions
1. Is it worth to add spanning-tree portfast trunk on port-channel and members interfaces ??
2.is it worth to add spanning-tree bpduguard enable on port-channel and memebrs interfaces ??
Thank you
Reza Sharifi
Your config looks correct, but if the servers are not from Cisco, you really don't need any Portchannels. All you would need to do is to configure the physical ports as trunk and configure high availability/IP flow on the VM side. The failover between the interfaces will work just fine.
Sure, these commands work on both PO and physical interfaces.
IPhoneRZ
hello,
Thanks for info
I have one more question about  these two commands:  spanning-tree portfast trunk and spanning-tree bpduguard enable on trunk ports connected to esx , are these commands safe ?? I mean is something to cosider before  implementing them on trunk port to ESX??
Those commands should be pretty safe to apply. Also, have a look at this post for more info. It is an old post but provides good info.
https://community.cisco.com/t5/switching/enable-bpduguard-on-spanning-tree-portfast-trunk-port-yes-or-no/td-p/2534826
