PortChannel between a VSS pair switches and HA pair of Firewalls
atsukane
Level 3
Level 3
Hi team,
I've been cabling up between VSS/stacked switches and HA pair of Firewalls like below, so they are connected across both switches:
I'm now working with a consultant for a project and he pointed out that this is wrong and it should be like this, so the failover kicks in properly:
Is this right?
3 Accepted Solutions
Reza Sharifi
Not sure what vendor firewall you are using, but if you are using clustering on the firewalls with one IP representing both devices, the diagram without the cross-connects should work fine. So, let's look at a couple of scenarios assuming the firewall on the right is the primary device and the VSS chassis on the right is also the primary device. If the primary VSS device fails, the secondary chassis on the left will take over and forward traffic to the passive firewall. Now in this situation, you want to make sure when the primary VSS goes down, the primary firewall hands over the traffic forwarding responsibility to the standby firewall so the traffic is not sub-optimal by going through the passive firewall, the interconnect, and then the active firewall. The second scenario is if there is a link failover between the primary switch and the primary firewall. In this case, the same concept as above should apply and the traffic should simply go through the secondary chassis and the new active firewall both on the left.
@atsukane you can cross connect the ASA or FTD to a VSS/VPC
If you use the threat defense device in an Active/Standby failover deployment, then you need to create separate EtherChannels on the switches in the VSS/vPC, one for each threat defense device. On each threat defense deivce, a single EtherChannel connects to both switches.
https://www.cisco.com/c/en/us/td/docs/security/secure-firewall/management-center/device-config/730/management-center-device-config-73/interfaces-settings-ifcs-firewall.html#id_90517
@atsukane no, it's not wrong at all if you are using VSS/VPC. The ASA has supported this configuration for a long time, as has the FTD.
8 Replies 8
depend what is port-channel is it L2 or L3?
Thanks @MHM Cisco World   It would be L3, the switch's default route is pointing to the Firewall. Thanks
Reza Sharifi
Thanks for the explanation @Reza Sharifi.  They are a HA pair of Cisco ASAs, soon to be replaced with Cisco FTDs.
The consultant was saying the cross-connect is WRONG, so I was a bit shocked as I've been following this design passed on from my mentor so just wanted to check with experts here.
Thanks @Rob Ingram "Figure 2. Active/Standby Failover and VSS/vPC" in the link is exactly how we are set up.
So it's not "wrong" as such.
atsukane
Level 3
Level 3
That's great, thanks a lot @Rob Ingram
