Portchannel between ASR1001 & 3750G down
empsonmatthew
We have an annoying issue that has happened twice now in the past couple of months. We are using a Cisco ASR1001 for our WAN connection to 2 remote sites.
From the ASR we have a 2 port etherchannel using LACP into our switch (Cisco 3750G). Twice now, the etherchannel has gone down, the interfaces were up but line protocol down.
The first time I consoled into the device and got halfway through typing a couple of show commands and the portchannel interface came up again by itself.
The second time, I tried shut/no shut on both the router and switch and got nothing. I reloaded the router and the portchannel came back up straight away.
The ASR is running:
Cisco IOS XE Software, Version 03.11.00.S – Standard Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(1)S, RELEASE SOFTWARE (fc2)
And the 3750 is running
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Here is the config on the ASR
interface Port-channel3
ip address X.X.X.X 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
channel-group 3 mode active
interface GigabitEthernet0/0/3
no ip address
negotiation auto
The config on the 3750 is:
interface GigabitEthernet1/0/6
description WAN – TO ASR1001
spanning-tree portfast
interface GigabitEthernet1/0/7
Has anyone run into anything similar or have any idea's on what could be causing it? Thanks
12 Replies 12
Reza Sharifi
Have you tried hard setting the ports to Gig?
speed 1000
duplex full
For us it was the version of IOS we were running on the ASR. TAC identified a bug. Once we upgraded, we did not experience any further issues.
Hi empsonmatthew,
Can you share the bug ID ? If not, could you at least tell us affected version and fixed one?
Andrei
CSCul35389 was the bug ID which was first resolved in 15.4(1)S1.
TAC advised us that 3.13.2S/15.4(3)S2 is the Cisco suggested release at the time. Haven't had an issue since.
It happened again, although ports were forced in Speed & Duplex.
I've just upgraded the IOS, hope it solves the problem.
@ empsonmatthew,
where did you get those messages from ?
i found the tracelogs/IOSCC_0-0.log.25219.**** logs filled with Pending connection to server, but nothing else.
Thank you,
Andrei Anghel
All logs we collected were sent to TAC. Didn't look at them myself sorry.
There are some requirements when using ether channel, like all physical interfaces have to have same duplex and speed, being in the same vlan and none of them can be a span port.
Aref
empsonmatthew
Thanks guys, I will try hard coding speed and duplex. Would it be advisable to remove 'spanning-tree portfast' as well from the switch ports? I think thats just a bit of left over old config.
Usually Portfast is for end devices, as they connect and disconnect from the network often and not between switches. I would remove it.
You are welcome. Portfast should be configured on all switch ports where there is no need for listening and learning state (no bpdus exchanged on those ports), in other words where the port has to be set immediately in forwarding state.
Aref
anghel.andrei
It happened to me also. I have solved it by harcoding speed and duplex on physical interfaces and port-channels on both sides. Since then , Port-Channel is up & running.
Iamnedmichael
Have same issue
