11-05-2009 06:16 AM - edited 03-06-2019 08:27 AM
I am looking for a simple command to show what ports are configured to be in what portchannel.
I have a couple of 6513s and am running 20 different port channels on each chassis. I just want an easy way to verify that I put the right ports in the right chassis.
So how can I show all the ports in port-channel 10 or all port assigned to channel-group 10?
Haven't found an easy way yet.
Thanks.
James
Solved! Go to Solution.
11-05-2009 06:19 AM
11-05-2009 06:19 AM
lol, just figured it out two minutes after I posted.
Show ETHERCHANNEL 10 Summary
Shows what ports are down and up.
Nothing to see here, move along!
James
11-05-2009 06:19 AM
Have you tried sh etherchannel summary?
HTH,
jerry
11-05-2009 07:07 AM
That was the exact command I was looking for.
Thanks.
James
