PortChannel Issue
zeeshanraza
I am facing an issue, that i connect my laptop with one port of 7609, the port(gi4/47) goes in to Up/Down state continuously due to which my port-channel ports(4/48 & 7/40) goes in err-disabled state and the port-channel goes down. What can be the reason for this
7 Replies 7
Leo Laohoo
Post the output to the command "sh interface Gi 4/47".
Hi Plx find
OSR1#show interfaces gigabitEthernet 4/47
GigabitEthernet4/47 is down, line protocol is down (notconnect)
  Hardware is C6k 1000Mb 802.3, address is 001d.45b9.f28e (bia 001d.45b9.f28e)
  Description: Reserved for local PC
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
     reliability 255/255, txload 0/255, rxload 0/255
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 51w4d
  Input queue: 0/2000/221/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     66193946 packets input, 14862452112 bytes, 0 no buffer
     Received 27417896 broadcasts (162080 multicasts)
     12 runts, 0 giants, 0 throttles
     42 input errors, 19 CRC, 0 frame, 179 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     40589807 packets output, 5427090316 bytes, 0 underruns
     48 output errors, 0 collisions, 0 interface resets
OSR1#
Let me rephrase my question ... Can you kindly plug a client back to Gi 4/47 and, if it's stable enough, wait for about 2 minutes and post the output to the command "sh interface Gi 4/47" and "sh counter interface Gi 4/47"?
currently it's not possible to connect the laptop at Gi4/47 because last time we have faced an outage due to this. So we can't do it without some MW. If you need some further info then plx inform.
Post the configuration of Gi 4/47 interface.
This clearly indicates that there is issue with the tx media such as ur UTP/Fiber cable.
Issue clear counter gi4/47 and test if these number increment even after that.
regards.
ensure the port gi4/47 is an access port  and not part of any other etherchannel.
post the o/p of sh run int gi4/47 , sh int gi4/47 switchport and sh run int po " x"
