portfast
pavan1989
Visitor
How do I enable portfast in Meraki Switches? Please let me know
BrechtSchamp
Level 11
Level 11
I believe if you set it to "access" mode in the port settings it automatically enables portfast.
Automatic edge port
MS switches will automatically place all ACCESS type interfaces into EDGE mode. This will cause for the interface to immediately transition the port into STP forwarding mode upon linkup. The port still participates in STP. So if the port is to be a part of the loop, the port eventually transitions into STP blocking mode.
Source:
https://documentation.meraki.com/MS/Deployment_Guides/Advanced_MS_Setup_Guide
BrechtSchamp
Level 11
Level 11
Automatic edge port
Source:
Philip D'Ath
Meraki Community All-Star
@BrechtSchamp is correct. Meraki switches running the more modern version of spanning tree known as RSTP, so this isn't really a "thing" anymore.
