possible routing/bridging issue - if not it's odd
codflanglers
I've got a strange problem. Here is the set up below:
6500 running OSPF and switching at site A
6500 running OSPF and switching at site B
3750 L3 switch running OSPF at site C
Router A and B have both an OSPF connection and a L2 trunk running between them (this is needed as there's lots of legacy stuff still running on common vlans). This seems to work fine and clients on site B are able to reach everything.
However, added new router C through OSPF to router B. Clients on Router B are then unable to reach anything on vlan X (a common vlan). Take the router C out of the equation and everything works again.
How can just adding a new network in to OSPF cause this? I would have thought if it's a routing/bridging conflict it would be happening all the time.
Any ideas?
5 Replies 5
andrew.prince
Level 10
Level 10
You may have a classfull boundry issue or a duplicate IP subnet.
Can you provide config/remove sensitive information.
Here is the router C config
version 12.2
no service pad
hostname Router C
boot-start-marker
boot-end-marker
logging buffered 16384
enable secret
enable password
username admin password
no aaa new-model
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
switch 1 provision ws-c3750e-24pd
switch 2 provision ws-c3750e-24pd
system mtu routing 1500
vtp domain XXX
vtp mode transparent
udld aggressive
ip subnet-zero
no ip source-route
ip routing
no ip domain-lookup
ip domain-name
ip name-server x.x.x.x
ip multicast-routing distributed
ip igmp ssm-map enable
no ip igmp ssm-map query dns
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos
crypto pki trustpoint TP-self-signed-3418629120
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3418629120
revocation-check none
rsakeypair TP-self-signed-3418629120
errdisable recovery cause udld
errdisable recovery cause link-flap
errdisable recovery interval 60
port-channel load-balance src-dst-ip
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree etherchannel guard misconfig
spanning-tree vlan 1-19 priority 4096
vlan internal allocation policy ascending
vlan 102
name X
vlan 103
name X
vlan 104
name X
vlan 105
name X
vlan 106
name X
vlan 107
name X
vlan 108
name X
vlan 109
name X
vlan 110
name X
vlan 111
name X
vlan 112
name X
vlan 113
name X
vlan 114
name X
vlan 115
name X
vlan 116
name X
vlan 117
name X
vlan 118
name X
vlan 119
name X
vlan 254
name X
ip ftp username
ip ftp password X
interface Loopback0
ip address x.x.x.x 255.255.255.255
interface Port-channel1
switchport trunk allowed vlan 1-19,254
switchport mode trunk
interface Port-channel2
interface Port-channel3
interface Port-channel4
interface Port-channel5
interface Port-channel6
interface Port-channel48
no switchport
ip address x.x.x.x 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
ip ospf message-digest-key 2 md5
mls qos trust dscp
no shut
end
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
shutdown
interface GigabitEthernet1/0/1
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust dscp
channel-group 1 mode active
interface GigabitEthernet1/0/2
queue-set 2
priority-queue out
mls qos trust dscp
channel-group 2 mode active
interface GigabitEthernet1/0/3
queue-set 2
priority-queue out
mls qos trust dscp
channel-group 3 mode active
interface GigabitEthernet1/0/4
queue-set 2
priority-queue out
mls qos trust dscp
channel-group 4 mode active
interface GigabitEthernet1/0/5
queue-set 2
priority-queue out
mls qos trust dscp
channel-group 5 mode active
interface GigabitEthernet1/0/6
queue-set 2
priority-queue out
mls qos trust dscp
channel-group 6 mode active
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
switchport access vlan 111
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
no switchport
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
ip igmp version 3
ip ospf message-digest-key 1 md5
udld port aggressive
mls qos trust dscp
channel-group 110 mode on
interface GigabitEthernet1/0/26
shutdown
interface GigabitEthernet1/0/27
shutdown
interface GigabitEthernet1/0/28
shutdown
interface GigabitEthernet2/0/1
queue-set 2
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/2
queue-set 2
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/3
queue-set 2
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/4
queue-set 2
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/5
queue-set 2
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/6
queue-set 2
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
no switchport
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
ip igmp version 3
mls qos trust dscp
interface GigabitEthernet2/0/26
shutdown
interface GigabitEthernet2/0/27
shutdown
interface GigabitEthernet2/0/28
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan102
ip dhcp relay information trusted
ip helper-address x.x.x.x
ip pim sparse-mode
interface Vlan103
ip pim sparse-mode
interface Vlan104
ip pim sparse-mode
interface Vlan105
ip pim sparse-mode
interface Vlan106
ip pim sparse-mode
interface Vlan107
ip pim sparse-mode
interface Vlan108
ip pim sparse-mode
interface Vlan109
ip pim sparse-mode
interface Vlan110
ip pim sparse-mode
ip igmp version 3
interface Vlan111
ip pim sparse-mode
interface Vlan112
ip pim sparse-mode
interface Vlan113
ip pim sparse-mode
interface Vlan114
ip pim sparse-mode
interface Vlan115
no ip address
shutdown
interface Vlan116
no ip address
shutdown
interface Vlan117
no ip address
shutdown
interface Vlan118
no ip address
shutdown
interface Vlan254
router ospf 100
log-adjacency-changes
area 0 authentication message-digest
redistribute connected
passive-interface default
no passive-interface GigabitEthernet1/0/25
no passive-interface GigabitEthernet2/0/25
no passive-interface port-channel48
network x.x.x.x 0.0.255.255 area 0
network x.x.x.x 0.0.0.3 area 0
ip classless
ip http server
ip http secure-server
ip pim ssm range 2
access-list 1 permit x.x.x.x
access-list 1 permit x.x.x.x 0.0.0.255
access-list 2 permit x.x.x.x 255.255.0.0
snmp-server community
snmp-server location
snmp-server contact
snmp-server system-shutdown
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps config-copy
snmp-server enable traps hsrp
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
control-plane
banner login ^C******* ^C
line con 0
exec-timeout 0 0
login local
line vty 0 4
access-class 1 in
login local
length 0
transport input ssh
transport output none
line vty 5 15
check VLAN/IP Subnet duplication/overlapps.
lamav
Level 8
Level 8
I don't think there isn't too much that can be said until we see the pertinent device configurations, as well as the output of the OSPF neighbors command and perhaps the sh ip ospf command.
Victor
The OSPF forms an adjacency fine, with Full neighbour status. Router B is the DR, with router C the BDR, which is what we want.
We are using a basic OSPF config, so just the network statement and md5 encryption. Interestingly, the vlan it has issues with is a /16 common vlan. You can still access it from another vlan, it just knocks out access to that /16 vlan from router B when the OSPF forms the adjaceny.
