Possible to collect Management Port (fa1) on Cat4500-X ?
mhiyoshi
Level 3
Level 3
Dear all,
I have already verified the following output however actually is it normally impossible to collect with management port
on Cat4500-X?
##### Management Port #####
Cat4500-X(config)#int fa1
Cat4500-X(config-if)#ip flow monitor MONITOR input
% Flow Monitor: Flow Monitor 'MONITOR' : Flow Monitor not supported on interface FastEthernet1.
Cat4500-X(config-if)#ip flow monitor MONITOR layer2-switched input
##### Data Port #####
Cat4500-X(config)#int te1/1
The following is related URL which says Flow collection is supported on Port however it does not say Management Port that is why...
[Catalyst 4500 Series Switch Software Configuration Guide, Release IOS XE 3.3.0SG and IOS 15.1(1)SG]
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/15-1/XE_330SG/configuration/guide/config/fnf.html
Flow collection is supported on multiple targets (Port, VLAN, per-port per-VLAN
(FNF can be enabled on a specific VLAN on a given port)) and on a port-channel (FNF is configured on the port-channel interface,
rather than individual member ports).
##### Export from Management port - Export is possible! #####
Cat4500-X(config)#flow exporter EXPORT
Cat4500-X(config-flow-exporter)#destination 192.168.1.254 vrf mgmtVrf
Cat4500-X(config-flow-exporter)#source fastEthernet 1
Cat4500-X#sh flow exporter
Flow Exporter EXPORT:
Description: User defined
Export protocol: NetFlow Version 9
Transport Configuration:
Destination IP address: 192.168.1.254
VRF label: mgmtVrf
Source IP address: 192.168.1.1
Source Interface: FastEthernet1
Transport Protocol: UDP
Destination Port: 9995
Source Port: 60484
DSCP: 0x0
TTL: 255
Output Features: Not Used
Masanobu Hiyoshi
7 Replies 7
Reza Sharifi
It appears that you need 03.08.00.E or later to get all the features you need. See link:
https://community.cisco.com/t5/switching/flexible-netflow-not-working-on-4500x-16/td-p/2856495/page/2
Currently the Cat4500-X is running on IOS-XE-Ver.3.6.9 but the bootflash has IOS-XE-Ver.3.9 so now I am going to try on upgrade version. Thank you for your quick feedback.
Cat4500-X#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.06.09.E
Cat4500-X#sh bootflash:
-#- --length-- ---------date/time--------- path
1 178796044 Oct 18 2019 13:30:44.0000000000 +00:00 cat4500e-universalk9.SPA.03.06.09.E.152-2.E9.bin
*omit
4 185394268 Dec 02 2019 06:33:03.0000000000 +00:00 cat4500e-universal.SPA.03.09.00.E.152-5.E.bin
Glad to help!
It appears that you have both versions loaded on the flash. So, it is just a matter of changing the boot variable to 03.09.00.E.152-5.E.bin and reloading the switch.
Hi Reza,
Thank you for your support, unfortunately even if it is IOS-XE-Ver.3.9.0.E, the output looks same.
Cat4500-X#sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.09.00.E RELEASE SOFTWARE (fc1)
*omit
Cat4500-X(config-if)#int te1/1
I appreciate if you can let me know support URL like release note, configuration guide something like that :)!.
There doesn't seem to be any document supporting this function on the out-of-band management port. So, you may want to use a regular port for this purpose.
That would be fine. Thank you very much!!.
Yes this info might be greatfully HTH (Hope This Helps).
Best Regards,
Masanobu Hiyoshi
