Possible to have four nexus 7000 switches within the same vpc domain?
Abdul
Is it possible to configure four Nexus-7000 switch within the same vpc domain?
these switches are connected to the access switches as attached picture.
Mark Malone
no 2  is the max per domain but you could have 2 domains interlinked , or just add in 5ks below still gives you plenty of resiliency if done in the x design
http://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
vPC domain is composed of two peer devices. Each peer device processes half of the traffic coming from the access layer. In case a peer device fails, the other peer device will absorb all the traffic with minimal convergence time impact.
Mark Malone
Thanks Mark Malone.
