Potential routing/ACL problem between subnets
m.junghage
Level 3
Level 3
We've a potential routing or ACL problem between two subnets that's routed in the same router. As I can see it traffic flows fine, there's no problem using rdp, http, ssh, telnet and udp streams between networks. The PBX engineers are complaining that their client applications that resides on Network A can't communicate correctly with the SQL server on Network B (10.0.0.25). When I'm using Wireshark to capture the traffic on both the server and client side I can se two way communication between them but after a few packets the client application chrashas and there's almost no traffic passed between them.
When we put the client on the same network as the server (Network B) everything works fine and a lot mor traffic is shown in Wireshark. I'm not 100% comfortable with old Cisco routers so I can't say definitely that the configuration is OK. Could someone be so kind and shed some light on this? The configuration pasted below.
Networks used:
Network A = Default data vlan 192.168.100.0/24
Default gw: 192.168.100.254 (Cisco 2600 router)
Network B = Voice vlan 10.0.0.0/24
Default gw: 10.0.0.250 (Cisco 2600 router)
Configuration:
! Last configuration change at 10:15:15 cet Wed Jun 22 2011 by Admin
version 12.3
service password-encryption
hostname devicename-1
boot-start-marker
boot-end-marker
logging buffered 265000 notifications
no logging console
logging monitor informational
enable secret 5 XXXXXXXXXXXXXXXXXXXX
enable password 7 XXXXXXXXXXXXXXXXXX
clock timezone cet 1
clock summer-time cet recurring last Sun Mar 2:00 last Sun Oct 3:00
aaa new-model
aaa authentication login default local
aaa authentication login no_tacacs enable
aaa authentication ppp default local
aaa session-id common
ip subnet-zero
ip cef
ip name-server XXX.XXX.XX.194
ip name-server XXX.XXX.XX.195
ip inspect max-incomplete high 1100
ip inspect one-minute high 1100
ip inspect name INTERNET tcp
ip inspect name INTERNET udp
ip inspect name INTERNET cuseeme
ip inspect name INTERNET ftp
ip inspect name INTERNET h323
ip inspect name INTERNET rcmd
ip inspect name INTERNET realaudio
ip inspect name INTERNET rpc program-number 1
ip inspect name INTERNET streamworks
ip inspect name INTERNET vdolive
ip inspect name INTERNET http
ip audit po max-events 100
voice call carrier capacity active
username XXXXX privilege 15 password 7 XXXXXXXXXXXXXX
controller E1 0/0
controller E1 0/1
ip ssh port XXXXX rotary 1 3
interface Loopback0
no ip address
interface FastEthernet0/0
no ip address
speed 10
full-duplex
interface FastEthernet0/0.100
encapsulation dot1Q 599
ip address XX.XXX.243.206 255.255.255.252
ip nat outside
no cdp enable
interface FastEthernet0/0.101
encapsulation dot1Q 1484
ip address 10.10.10.6 255.255.255.252
ip nat inside
interface FastEthernet0/1
no ip address
speed 100
full-duplex
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 172.24.1.1 255.255.255.0
interface FastEthernet0/1.100
description **DMZ**
encapsulation dot1Q 100
ip address XX.XXX.135.249 255.255.255.248
ip access-group 2000 out
ip nat outside
ip inspect INTERNET in
interface FastEthernet0/1.101
description **internal data vlan**
encapsulation dot1Q 101
ip address 192.168.100.254 255.255.255.0
ip access-group 101 out
ip nat inside
interface FastEthernet0/1.102
description **random vlan**
encapsulation dot1Q 102
ip address 192.168.102.1 255.255.255.0
ip access-group 102 out
ip nat inside
interface FastEthernet0/1.103
interface FastEthernet0/1.150
description VOICE_VLAN
encapsulation dot1Q 150
ip address 10.0.0.250 255.255.255.0
ip nat inside
router rip
version 2
redistribute connected
redistribute static
network 10.0.0.0
network 192.168.100.0
neighbor 10.10.10.5
neighbor 10.10.10.2
distribute-list 1 out FastEthernet0/0.101
ip nat pool internet XX.XXX.135.254 XX.XXX.135.254 netmask 255.255.255.252
ip nat inside source list 100 pool internet overload
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 XX.XXX.243.205
ip route 192.168.50.0 255.255.255.0 192.168.100.225 permanent name FINNPOWER
access-list 1 remark Filter Routes
access-list 1 deny   XX.XXX.135.248
access-list 1 deny   XX.0.0.0
access-list 1 deny   XX.XXX.243.204
access-list 1 permit any
access-list 10 remark SNMP Access Control
access-list 10 permit 192.168.150.0 0.0.0.255
access-list 10 permit 172.24.0.0 0.0.0.255
access-list 100 remark Nat Overload Networks
access-list 100 permit ip 192.168.100.0 0.0.0.255 any
access-list 100 permit ip 192.168.102.0 0.0.0.255 any
access-list 100 permit ip 192.168.103.0 0.0.0.255 any
access-list 100 permit ip 10.0.0.0 0.0.0.255 any
access-list 101 remark internal data vlan
access-list 101 permit tcp host XX.XXX.110.197 host 192.168.100.20 eq domain
access-list 101 permit udp host XX.XXX.110.197 host 192.168.100.20 eq domain
access-list 101 permit ip 192.168.50.0 0.0.0.255 host 192.168.100.20
access-list 101 permit ip host 192.168.100.20 192.168.50.0 0.0.0.255
access-list 101 permit ip 192.168.50.0 0.0.0.255 host 192.168.100.24
access-list 101 permit ip host 192.168.100.24 192.168.50.0 0.0.0.255
access-list 101 permit ip 172.24.0.0 0.0.0.255 any
access-list 101 permit ip 172.25.0.0 0.0.0.255 any
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any echo-reply
access-list 101 permit tcp any any eq 1723
access-list 101 permit gre any any
access-list 101 permit tcp 192.168.50.0 0.0.0.255 192.168.100.0 0.0.0.255 eq 3389
access-list 101 permit tcp 192.168.100.0 0.0.0.255 192.168.50.0 0.0.0.255 eq 3389
access-list 101 permit ip 0.0.0.0 255.255.255.0 any
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
access-list 102 remark **random vlan**
access-list 102 permit ip host 192.168.100.225 192.168.102.0 0.0.0.255
access-list 102 permit ip host 192.168.100.226 192.168.102.0 0.0.0.255
access-list 102 permit ip host 192.168.100.227 192.168.102.0 0.0.0.255
access-list 102 permit ip host 192.168.100.228 192.168.102.0 0.0.0.255
access-list 102 permit ip host 192.168.100.229 192.168.102.0 0.0.0.255
access-list 102 permit ip host 192.168.100.135 192.168.102.0 0.0.0.255
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any any unreachable
access-list 102 permit icmp any any echo-reply
access-list 103 remark TelnetAccess
access-list 103 permit ip 172.24.0.0 0.0.0.255 any
access-list 103 permit ip 192.168.100.0 0.0.0.255 any
access-list 103 permit ip 10.0.0.0 0.0.0.255 any
access-list 104 remark TelnetAccess
access-list 104 permit ip 172.24.0.0 0.0.0.255 any
access-list 104 permit ip 192.168.100.0 0.0.0.255 any
access-list 104 permit ip host YY.YY.163.208 any
access-list 110 remark RateLimit SharePool
access-list 110 permit ip 192.168.102.0 0.0.0.255 any
access-list 110 permit ip any 192.168.102.0 0.0.0.255
access-list 110 permit ip any 192.168.103.0 0.0.0.255
access-list 110 permit ip 192.168.103.0 0.0.0.255 any
access-list 120 permit ip any any
access-list 2000 remark **DMZ**
access-list 2000 permit tcp any host XX.XXX.135.252 eq domain
access-list 2000 permit udp any host XX.XXX.135.252 eq domain
access-list 2000 permit tcp any host XX.XXX.135.252 eq 443
access-list 2000 permit tcp any host XX.XXX.135.252 eq www
access-list 2000 permit tcp any host XX.XXX.135.252 eq smtp
access-list 2000 permit tcp any host XX.XXX.135.252 eq pop3
access-list 2000 permit tcp any host XX.XXX.135.252 eq 143
access-list 2000 permit tcp any host XX.XXX.135.252 eq 636
access-list 2000 permit tcp any host XX.XXX.135.252 eq nntp
access-list 2000 permit tcp any host XX.XXX.135.252 eq 1723
access-list 2000 permit udp any host XX.XXX.135.252 eq netbios-ns
access-list 2000 permit udp any host XX.XXX.135.252 eq netbios-dgm
access-list 2000 permit gre any host XX.XXX.135.252
access-list 2000 permit tcp any host XX.XXX.135.250 eq domain
access-list 2000 permit udp any host XX.XXX.135.250 eq domain
access-list 2000 permit tcp any host XX.XXX.135.250 eq 443
access-list 2000 permit tcp any host XX.XXX.135.250 eq www
access-list 2000 permit tcp any host XX.XXX.135.250 eq smtp
access-list 2000 permit tcp any host XX.XXX.135.250 eq pop3
access-list 2000 permit tcp any host XX.XXX.135.250 eq 143
access-list 2000 permit tcp any host XX.XXX.135.250 eq 636
access-list 2000 permit tcp any host XX.XXX.135.250 eq nntp
access-list 2000 permit tcp any host XX.XXX.135.250 eq 1723
access-list 2000 permit udp any host XX.XXX.135.250 eq netbios-ns
access-list 2000 permit udp any host XX.XXX.135.250 eq netbios-dgm
access-list 2000 permit gre any host XX.XXX.135.250
access-list 2000 permit ip any host XX.XXX.135.251
access-list 2000 permit ip 172.24.0.0 0.0.0.255 any
access-list 2000 permit icmp any any time-exceeded
access-list 2000 permit icmp any any unreachable
access-list 2000 permit icmp any any echo-reply
access-list 2000 permit gre any any
access-list 2000 permit tcp any any eq 1723
snmp-server community XXXXXXX RO 10
snmp-server community XXXXXXX RW 10
snmp-server enable traps tty
dial-peer cor custom
banner login
All login attempts is recorded!
line con 0
line aux 0
line vty 0
access-class 104 in
password 7 XXXXXXXXXXXXXXXXXXXXXXXX
line vty 1 3
access-class 104 in
rotary 1
transport input ssh
line vty 4
access-class 104 in
ntp clock-period 17179477
ntp server XX.XXX.XXX.XXX prefer
end
2 Accepted Solutions
Hi Markus,
1. So I should configure two new subinterfaces with vlan:s and add all correct acl:s and when the configuration is complete change "switchport access vlan 1XX" to direct traffic to the new vlan:s?
No you no need to configure any new subinterfaces, only thing is just need to differentiate the access-lists for each vlan (data and voice)
2.
Network A (192.168.100.0/24) should be able ta access all the networks according to the existing acl:s and full access to Network B (10.0.0.0/24)
access-list 101 deny any any
Network B (10.0.0.0/24) should be able to use http, https, icmp and ntp towards the outside on vlan 100 and full access to Network A (192.168.100.0/24)
access-list 102 permit tcp 10.0.0.0 0.0.0.255 host XX.XXX.135.252 eq 443
access-list 102 permit tcp 10.0.0.0 0.0.0.255 host XX.XXX.135.252 eq 80
access-list 102 permit tcp 10.0.0.0 0.0.0.255 host XX.XXX.135.252 eq icmp
access-list 102 permit tcp 10.0.0.0 0.0.0.255 host XX.XXX.135.252 eq ntp
access-list 102 permit ip 10.0.0.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 102 deny any any
Now apply the above defined access list rules to the vlan's like below....
ip access-group 101 in
ip nat inside
ip access-group 102 in
ip nat inside
Please click on the correct answer if this answered your question.
Naidu.
Hi Markus,
Please remember to rate all the helpfull posts which will encourage others in this forum.
Naidu.
5 Replies 5
Latchum Naidu
The first mistake is that you used the same access-list under both data and voice vlans.
You need to change your accesslists.
I would suggest you to change vlan, I mean use different vlans once defined as per requirement and then apply under the respective vlans.
To suggest in the configuring of vlan's I need to know what and all needs to be access from data vlan (192.168.100.0/24 to 10.0.0./24 and vice versa).
Naidu.
Thank you for your reply Naidu,
Let's see if my answers are sufficient enough for you.
2.
Markus
Hi Markus,
2.
ip nat inside
ip nat inside
Naidu.
Thank you for the configuration example! I understand the changes now. I will enter the commands later this evening when the production network is unused.
Markus
Hi Markus,
Naidu.
