Power Consumption Calculation
Mohammed Moqbel
Community Member
Total output current for my customed C6807 is 37.85A @52V.
Now is this current value 37.85A will be minimized if it is @220V?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Hmm, not sure why it's showing 52V, but since wattage is volts times amps, as you increase the voltage you can decrease the amperage to obtain the same wattage.
Joseph W. Doherty
Disclaimer
Posting
Thanks Joseph.
I will consider the whole power supply wattage 3000watt/200v(worst phase)=15A
I got below from Cisco CPC notes:
  • The Catalyst 6807XL backplane power connectors for the linecards, fan trays and Supervisors operate at 52V.The power supplies take the power from the source and convert it into a 52V feed for these power connectors.
