Power Controller reports power Imax error detected
ernest617
My 3560 switch w/ IOS 12.2(35)SE have below message last night. Would anyone know what happen?
Sep 23 18:54:58.468 UTC: %ILPOWER-7-DETECT: Interface Fa0/10: Power Device dete
ted: IEEE PD
Sep 23 18:54:58.468 UTC: %ILPOWER-5-INVALID_IEEE_CLASS: Interface Fa0/10: has d
tected invalid IEEE class: 7 device. Power denied
Sep 23 18:57:37.542 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error,
Interface Fa0/12: Power Controller reports power Imax error detected
Sep 23 18:57:44.580 UTC: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no lon
er detected on port Fa0/12, port set to untrusted.
Sep 23 18:57:48.674 UTC: %ILPOWER-7-DETECT: Interface Fa0/12: Power Device deteted: Cisco PD
Sep 23 18:57:48.741 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/12: Power Controller reports power Tstart error detected
Thanks and Regards
Ernest
32 Replies 32
prashantk
I am also having the same logs under my 3560-cx switch for CISCO AP as a PD.
TShoot steps which I follows:
1) Run cable test
Switch#test cable-diagn tdr int G1/0/3
verify: Switch# sh cable-diagn tdr int G1/0/3 - No cable Fault
2)
Switch(config)# int G1/0/3
Switch(config-if)# power inline never
Switch(config-if)# shut
Switch(config-if)# no shut
Switch(config-if)#power inline auto
Switch(config-if)# power inline port 2-event  (in my switch IOS  Version 15.2(7)E2 )
Switch(config-if)# exit
Also applied static power allocation and all possible config. STILL NO LUCK.
3) Upgrade the firmware IOS  Version 15.2(7)E2. Still Out of luck
4) Finally, change the Ethernet cable. Everything is working fine. ISSUE Resolved.
With Regards,
Prashant K
YDOT1Q
New Cat 9300 running 17.03.05 has this issue with one particular type of PD. But the PD works fine with external POE injector (Axis Midspan).
Configured 2x-mode, the error keeps happening.
swycs
Hi there,
Any solution on the Cat 9300, we have the same issue providing power to an POE+ sensor. Any suggestions for a solution
