catalyst c1000 H stacking
aeddicott
Community Member
Having issues setting up  x2 c1000 catalyst switches in a horizontal stack. 2nd switch not being picked up. is there any documentation that explains how to set this up set by step?
Torbjørn
You can configue single IP management/stacking with the following procedure:
! Configure on both switches
configure
terminal
! Use differing switch numbers on each switch
switch {switch number} hstack-port {stack-port-number} {stack-port/interface}
end
write memory
reload
Once the switches have reloaded they should be managed as one. You can verify the status using "show switch hstack-ports". You can read more about this here: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/software/releases/15_2_7_e/configuration_guides/stacking/b_1527e_single_ip_management_c1000_cg.html
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
balaji.bandi
