05-17-2024 01:17 AM
My C1000-48FP-4G-L having issued cannot power up POE/POE+ AP devices and the switch running on latest stable version c1000-universalk9-tar.152-7.E10.tar.
May 17 08:05:35.735: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
May 17 08:05:37.487: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected. Is there any thought or suggestion?
best Regards,
Sophearom
05-17-2024 01:33 AM
- Enable LLDP on the particular port ,
M.
05-17-2024 01:41 AM
khPNHcoSW03#show ll
khPNHcoSW03#show lldp inter
khPNHcoSW03#show lldp interface gig
.May 17 08:38:32.679: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD1/0/3
.May 17 08:38:35.680: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
GigabitEthernet1/0/3:
Tx: enabled
Rx: enabled
Tx state: INIT
Rx state: WAIT PORT OPER
khPNHcoSW03#
.May 17 08:38:47.680: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
.May 17 08:38:50.680: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
.May 17 08:39:02.679: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
.May 17 08:39:05.091: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
.May 17 08:39:17.679: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
.May 17 08:39:20.680: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
.May 17 08:39:32.150: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
.May 17 08:39:35.681: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
.May 17 08:39:47.680: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
.May 17 08:39:50.164: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
.May 17 08:40:02.680: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
.May 17 08:40:05.681: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
May 17 08:40:17.680: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
May 17 08:40:20.681: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
.May 17 08:40:32.947: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
.May 17 08:40:35.231: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Imax error detected
05-17-2024 01:42 AM - edited 05-17-2024 01:43 AM
I did - but still not help. also, 2 others switch 9200L series running to have the same issued.
05-17-2024 02:11 AM
- Try to have a go with CDP instead of LLDP , but don't configure both ,
M.
05-20-2024 01:01 AM
I'm tried but still no luck. somehow i see in forum very common issued recently but only from 9000 Series not see C1000 Series list in that. for my case i have both C9200L and C1000 Series impact right now.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCwd78924
05-20-2024 02:07 AM
- Check the complete lldp setup procedure for the interface according to :
https://documentation.meraki.com/MR/Other_Topics/Low_Power_Mode_on_Cisco_Switches
If still not working also use and implement the last step mentioned in the document ;
At this point, the switch and access point should be able to negotiate up to the required power level. If this is still not occurring, make sure the switch port is allowing up to 30W of power for the connected device:
1 |
Switch# configure terminal |
2 |
Switch(config)# interface interface_id |
3 |
Switch(config-if)# power inline max 30000 |
4 |
Switch(config-if)# end |
Note: On newer Cisco switches, substitute "power inline max 30000" for "power inline static max."
PS : ignore the red colors ,
M.
05-20-2024 02:29 AM
Sorry, marce1000 I have follow your advise still no luck...
05-20-2024 02:59 AM
05-20-2024 06:09 AM
- A few other items which you may check :
- check output from : show cdp neighbors details and look at the info's for where the AP is connected to
Is the issue related to a single AP or a particular ap-model ?
M.
05-20-2024 07:19 PM
We have a single AP model U6-LR - around 12 APs which 7 APs has have issued.
I have done some test connect my APs that have issued to others Ruijie PoE switch (non cisco) it can power up and working fine. and Poll new switch C1000 connected to APs and I got the same issued as C9200L series.
05-20-2024 11:59 PM
- You may also post the original problem in https://community.ui.com/ (e.g.)
M.
05-21-2024 03:56 AM
- Added reply ; could you try and configure power inline port 2x-mode , on the particular port (interface) where the AP is connected to , (if the particular command is available on the C1000-48FP-4G-L)
M.
05-21-2024 04:38 AM
Hi, we also tried that similar command power inline static max 30000. But the behavior on port previous message gone ( continued port status down and up) not working
05-21-2024 04:44 AM
- Bit confusing ; did you effectively try power inline port 2x-mode
too ?
M.
