power module denied power on module 7 on a 6509
Charles Hill
We have installed a 6509 and module 7 and 8 are being denied power. Any ideas why we are bieng denied power.
Something that will get you by until you get bigger power supplies is to run the existing power supplies in combined mode. Unfortunately you will lose your power supply redundancy. Here is the command to activate it.
"power redundancy-mode combined"
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa8.shtml#power_red
Mark
10 Replies 10
Jon Marshall
Charles
Please post output of
1) sh module
2) sh power
Jon
Here is the output from sh module and sh power. Any help is greatly appreciated.
Mayberry#sh module 7
Mod Ports Card Type Model Serial No.
7 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1216MF4X
Mod MAC addresses Hw Fw Sw Status
7 001f.9e22.af8c to 001f.9e22.afbb 2.7 Unknown Unknown PwrDeny
Mod Sub-Module Model Serial Hw Status
7 Centralized Forwarding Card WS-F6700-CFC SAL1216N2BK 4.0 PwrDeny
Mod Online Diag Status
7 Not Applicable
Mayberry#sh power
system power redundancy mode = redundant
system power total = 2771.16 Watts (65.98 Amps @ 42V)
system power used = 2551.92 Watts (60.76 Amps @ 42V)
system power available = 219.24 Watts ( 5.22 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-3000W 2771.16 65.98 OK OK on
2 WS-CAC-3000W 2771.16 65.98 OK OK on
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 WS-C6509-E-FAN 210.00 5.00 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 WS-X6708-10GE 444.36 10.58 444.36 10.58 on on
2 WS-X6708-10GE 444.36 10.58 444.36 10.58 on on
3 WS-X6708-10GE 444.36 10.58 444.36 10.58 on on
4 WS-X6708-10GE 444.36 10.58 444.36 10.58 on on
5 WS-SUP720-3B 282.24 6.72 282.24 6.72 on on
6 (Redundant Sup) - - 282.24 6.72 - -
7 WS-X6748-GE-TX 325.50 7.75 - - on off (FRU-power denie
d)
8 WS-X6748-GE-TX 325.50 7.75 - - on off (FRU-power denie
d)
Mayberry#
Sorry Charles but can you post full output of sh module or post which version of IOS/CatOS you are using ?
Jon
here is the sh ver.
Mayberry# sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 1
2.2(33)SXH2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sun 30-Mar-08 13:21 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
Mayberry uptime is 40 minutes
Uptime for this control processor is 40 minutes
Time since Mayberry switched to active is 39 minutes
System returned to ROM by power cycle at 09:29:43 UTC Tue May 6 2008 (SP by pow
er on)
System image file is "bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXH2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.4) with 983008K/65536K bytes of m
emory.
Processor board ID SMG1217N2AY
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
16 Virtual Ethernet interfaces
98 Gigabit Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Here is the show module.
Mayberry#sh module
1 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1218PFDH
2 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1217NU2D
3 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1218PFEW
4 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1218PFD7
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1217NJBW
8 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1218P76X
1 001d.4577.ce80 to 001d.4577.ce87 1.4 12.2(18r)S1 12.2(33)SXH2 Ok
2 001d.4577.c248 to 001d.4577.c24f 1.4 12.2(18r)S1 12.2(33)SXH2 Ok
3 001d.4577.ce70 to 001d.4577.ce77 1.4 12.2(18r)S1 12.2(33)SXH2 Ok
4 001d.4577.cf70 to 001d.4577.cf77 1.4 12.2(18r)S1 12.2(33)SXH2 Ok
5 0016.9de6.8d64 to 0016.9de6.8d67 5.6 8.5(2) 12.2(33)SXH2 Ok
8 0021.55a5.e158 to 0021.55a5.e187 2.7 Unknown Unknown PwrDeny
1 Distributed Forwarding Card WS-F6700-DFC3C SAL1217NNGY 1.0 Ok
2 Distributed Forwarding Card WS-F6700-DFC3C SAL1217NA0W 1.0 Ok
3 Distributed Forwarding Card WS-F6700-DFC3C SAL1217NK2P 1.0 Ok
4 Distributed Forwarding Card WS-F6700-DFC3C SAL1217NFYX 1.0 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B SAL1217NK96 2.3 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL1217NLUZ 3.1 Ok
8 Centralized Forwarding Card WS-F6700-CFC SAL1216MUMC 4.0 PwrDeny
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
7 Not Applicable
8 Not Applicable
Charles
You only have 5.22 Amps available but each WS-X6748-GE-TX module needs 7.00 Amps @ 42V. See attached release notes - do a search for WS-X6748-GE-TX.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html
So you will need to upgrade your power supplies.
Jon
Thank you!
How do you upgrade a power supply? Replace it?
Yes. From the same link here are the available power supplies. Make sure you have an IOS that will support them. You should be okay.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html#wp2566981
Jon
Mark
