Power on ethernet - Help
abdave
I have a switch 4507 which has default
PoE Enabled.today first time I am testing this feature.But it is not detecting any device as Wireless Access point or IP phone.Any immediate help will be appreciated.
Hello Abhishek,
I see
one power supply is off.
What is important is that the linecards look like the wrong type:
WS-X4548-GB-RJ45V this support PoE you have WS-X4548-GB-RJ45 and the missing V is for PoE
you can see in the link of first Massimiliano's post: all linecards supporting PoE have a final V in the part number.
Hope to help
Giuseppe
11 Replies 11
Thanks , BUT Strage problem is I am not seeing "POWER" command at all.Any idea why it is not there?
what is the version of IOS you're using?
Massimiliano.
The Version is Version 12.2(20)EW3.Thanks
What modules do you have installed in Catalyst 4500?
Massimiliano.
Here it is :
2 Sup Eng. and three 48 port blades
Switch#sh module
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4013+ JAE1015ZRA6
2 2 1000BaseX (GBIC) Supervisor(standby) WS-X4013+ JAE1015ZW7
Hello Abhishek,
it is important to provide the following info:
a) what model are the 48 port blades linecards sh module provides this info
b) what power supplies are installed in the chassis try to see if sh power or sh env power or sh env all provides this
because not all 48 FE or GE linecards are PoE capable and also the power supplies must be strong enough for the extra power.
Hope to help
Giuseppe
Thanks for response.Attached is the info.
Plz Let me know if you can find any solution why it is not showing power command .
Switch#sh environment
no alarm
Chassis Temperature = 36 degrees Celsius
Chassis Over Temperature Threshold = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-1300ACV AC 1300W good good good
PS2 PWR-C45-1300ACV AC 1300W bad/off bad/off bad/off
Power supplies needed by system : 1
Power supplies currently available : 1
Switch# sh module
more ...
Switch# sh module
[11:23] Manish(9886746715): 3 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE10170QRM
4 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE10170S2R
5 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE12046740
M MAC addresses Hw Fw Sw Status
1 0014.6947.1e40 to 0014.6947.1e41 4.1 12.2(20r)EW1 12.2(20)EW3 Ok
2 0014.6947.1e42 to 0014.6947.1e43 4.1 12.2(20r)EW1 12.2(20)EW3, Ok
3 0017.9516.47d0 to 0017.9516.47ff 2.2 Ok
4 0017.94cf.ed20 to 0017.94cf.ed4f 2.2 Ok
5 001f.6c1e.2670 to 001f.6c1e.269f 2.4 Ok
System Failures:
Power Supply: bad/off (see 'show power')
Hello Abhishek,
I see
Hope to help
Giuseppe
Great Thanks !!! This clarifies everything.
