01-08-2019 09:50 AM - edited 03-08-2019 04:58 PM
Hello Everyone
I have the following problem/question. I don't understand why the POWER BUDGET on the below picture are different for each switch.
Based on the INLINE power, each switch is taking only 190W
Switch one: 510 + 190 = 700
Switch two: 515 + 190 = 705
Switch three 541 + 190 = 731
Switch four 480 + 190 = 670
Thank you
01-08-2019 10:18 AM
the Power-priority high and Power-priority low values are different for each switch in the stack (which is in power sharing mode), hence the different power budget values...
01-08-2019 10:34 AM
Thank you Georg
I executed the following command
SHOW POWER INLINE PRIORITY
I see that all of the ports are LOW. Is the another command that I'm missing?
First
Second
Third
01-08-2019 10:56 AM
by default, all ports are set to low priority, unless you change that manually by entering the power inline port priority { high | low } interface configuration command...
01-08-2019 10:59 AM
Hello
I understand that but the reason I show you those screenshots was to confirm that all ports are in LOW priority and even in that case the BUDGET is different for all switches. That is what I'm trying to figure out.
Thank you
01-08-2019 11:51 AM
try and set the power high and low priority values to the same on all switches, and check if the power budget is the same then...
01-08-2019 12:23 PM
Priorities are the same in every single switch.
Still the same
