Power Stacking Cisco3750-X
Khizersaleem
Hi Cisco Buddies
I'm a little bit confused on a point in a power stacking.
Is it safe to plug the power stacking cables while the stack switches are power on?
What is the recommended way?
Your reply will be highly appreciated.
#3750-X #Power_Stacking
Deepak Kumar
Yes, it is safe. But Cisco is not recommended to play with Power stack until you really not need.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Hi Deepak
Thanks for your kind reply, can I have any official document link regarding the said issue.
Best Regards
Please go through the white paper.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/white-paper-c11-737746.html
Deepak Kumar
Deepak Kumar,
Thanks, Deepak!
