Power supply and PoE for IE-2000-16PTC-G-E
chbgcisco
We are looking at purchasing a Cisco industrial switch IE-2000-16PTC-G-E and there are several power supplies listed for this switch. We are unsure which one to get that will power PoE on all 16 ports. Also, we are unsure how many PoE ports this switch actually supports. Does it support 16 PoE ports or just 4?
5 Replies 5
Reza Sharifi
According to the datasheet, this model supports only 4 POE ports. The other models don't have any POE ports.
https://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-2000-series-switches/datasheet-c78-730729.html
Darn! When I looked at the picture of it, it seemed like all the yellow lines meant that they were PoE ports so that's why I thought it had 16 ports. I do see in the one graphic that it says 4 PoE/PoE+ ports. I find it odd that they didn't really list that out in the tables. Thanks for checking!
I agree. The datasheets sometimes are not very clear and don't include everything.
I saw the data sheet, but there's nothing on that page that links to the DC Power Supply Model numbers.
I was able to find the Power Supply Model numbers from Table 12 on the ie2000 hardware installation guide.
https://www.cisco.com/c/en/us/td/docs/switches/connectedgrid/ie2000u/hardware/installation/guide/IE2000u/HIGINSTL.html?dtid=osscdc000283
