Power supply error, Cisco switch 3750
jcarranza2009
Can someone help me with a  power supply problem...?
Switch cisco WS-C3750-24P is showing "Unavail" from sh env all
Switch3750#sh env all
FAN is OK
TEMPERATURE is OK
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  Built-in                                         Unavail
2  Built-in                                         Good
3  Built-in                                         Good
4  Built-in                                         Good
Does it means that power supply 1 was removed? failed?
Do you know about another command to see more details?
2 Accepted Solutions
nkarpysh
Can you pls attach full outputs from "sh env all" "sh env st". It seems that you have RPS connected and those provide power thus one of the internal PSs is unavailable. You can force RPS to stop providing power and see if internal comes up.
Nik
HTH,
Niko
smogra
If internal power has short hit, device can't switch back to internal supply
while power restored and start using external power.
To fix the issue, you need to disconnect external power to normalize the status.
Hope that helped.
Cheers,
Sweta
Please rate useful posts.
nkarpysh
Nik
HTH,
Niko
smogra
Hope that helped.
Cheers,
Sweta
Thanks a lot, switch was rebooted and the PS-1 came to "good".
Hi All,
Can you please help to fix the issue,
sw03#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 45 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 58 Degree Celsius
Red Threshold    : 68 Degree Celsius
1  Built-in                                         Unavail
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Active          <>
sw03#sh env st
SWITCH: 1
FAN is OK
TEMPERATURE is OK
POWER is FAULTY
RPS is SUPPLYING
As per the sh env stack, seem like power is faulty ?. Can Someone please tell how to rectify the problem.
Madan
