Power supply failure
kj9000
We have a stack of 4 WS-C3850-48U's running IOS ver. 16.6.5. all running dual power supplies. One of the members registered a power supply failure. It was hot swapped out with a new one however the switch is still showing a power supply failure error. Is there any reset or other options for remedying this short of replacing the switch?
Thanks in advance.
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  PWR-C1-1100WAC      DTN2046V39D  OK              Good     Good     1100
1B  PWR-C1-1100WAC      DTN2046V39B  OK              Good     Good     1100
2A  PWR-C1-1100WAC      LIT20452ZQG  OK              Good     Good     1100
2B  PWR-C1-1100WAC      LIT20452Y93  OK              Good     Good     1100
3A  PWR-C1-1100WAC      LIT200305ZY  OK              Good     Good     1100
3B  PWR-C1-1100WAC      DTN2039V3UC  OK              Good     Good     1100
4A  PWR-C1-1100WAC      DTN2039V36B  OK              Good     Good     1100
4B  PWR-C1-1100WAC      DTN2203V0UQ  Supply Failure  Bad      Bad      1100
Leo Laohoo
Could be an IOS bug.
Reza Sharifi
Did you see the same error message before replacing it? if yes, it could be that the fist PSU was never bad. So, as Leo said, it could be an IOS bug. We had the same problem (don't remember the exact error message) with some 3850 stacked and the only way we got it fixed was by upgrading the IOS. Sometimes reloading the stack or just that switch can fix it temperately but as you know that is usually not a good solution.
Leo Laohoo
Wait a second ... It says "Supply Failure".
That does NOT mean the Power Supply is faulty. That means the power INPUT FEED is faulty.
