01-19-2017 05:27 AM - edited 03-08-2019 08:58 AM
Hi. one of power supply status in nexus 9336 showing absent while another supply status is ok. Not sure what could be possible cause of it. Does it mean power supply has fail OR supply is not inserted properly into slot and not detecting.
Please clear me here.
N9K-A# sh environment
Power Supply:
Voltage: 12 Volts
Power Actual Actual Total
Supply Model Output Input Capacity Status
(Watts ) (Watts ) (Watts )
1 ------------ 0 W 0 W 0 W Absent
2 N9K-PAC-650W 180 W 194 W 649 W Ok
Power Usage Summary:
Power Supply redundancy mode (configured) PS-Redundant
Power Supply redundancy mode (operational) Non-Redundant
Total Power Capacity (based on configured mode) 649.92 W
Total Grid-A (first half of PS slots) Power Capacity 0.00 W
Total Grid-B (second half of PS slots) Power Capacity 649.92 W
Total Power of all Inputs (cumulative) 649.92 W
Total Power Output (actual draw) 180.00 W
Total Power Input (actual draw) 194.00 W
Total Power Allocated (budget) N/A
Total Power Available for additional modules N/A
Clock:
01-19-2017 06:04 AM
Usually that means no PSU inserted. Try "sh env power" to get more details.
01-19-2017 06:24 AM
Thanks Reza, please see below required output..
N9K-A# sh env power
Power Supply:
Voltage: 12 Volts
2 N9K-PAC-650W 179 W 192 W 649 W Ok
Total Power Output (actual draw) 179.00 W
Total Power Input (actual draw) 192.00 W
N9K-A# sh env power de
Power Supply:
Voltage: 12 Volts
2 N9K-PAC-650W 182 W 197 W 649 W Ok
Total Power Output (actual draw) 182.00 W
Total Power Input (actual draw) 197.00 W
Power Usage details:
Power reserved for Supervisor(s): N/A
Power reserved for Fabric, SC Module(s): N/A
Power reserved for Fan Module(s): N/A
Total power reserved for Sups,SCs,Fabrics,Fans: N/A
Are all inlet chords connected: Yes
Power supply details:
PS_2 total capacity: 649 W Voltage:12V
Pin:197.50W Vin:232.25V Iin:0.85A Pout:182.75W Vout:12.07V Iout:15.25A
Chord connected to 220v AC
Software-Alarm: No
Hardware alarm_bits reg0: 2,
Reg0 bit1: A comm, memory or logic fault
01-19-2017 06:27 AM
Also can you please confirm if I can remove power supply and insert it back while switch is running OR do I need to shutdown switch.
is it complete hot swappable? would it cause any issue if if do this when is switch up and running.
01-19-2017 06:38 AM
The PSUs are hot swappable (see link below), but if you can do it during a maintenance window, it is preferable.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-729404.html
04-10-2018 07:55 PM
Module Status
Powered-Up value: 1
Powered-Dn value: 2
Pwr-Denied value: 3
Err-Pwd-Dn value: 4
Absent value: 5
Present value: 6
Failure value: 10
Pwr-Cycld value: 8
show environment fex { all | i } [ temperature | power | fan ] [ __readonly__ fandetails fan_filter_status TABLE_faninfo fanfex fanname fanmodel fanhwver fanstatus powersup voltage_level TABLE_psinfo psfex psnum psmodel watts amps ps_status TABLE_mod_pow_info modfex modnum mod_model watts_requested amps_requested watts_alloced amps_alloced modstatus power_summary powfex ps_redun_mode tot_pow_capacity reserve_sup pow_used_by_mods available_pow TABLE_tempinfo tempfex tempmod sensor majthres minthres curtemp alarmstatus ]
