Flexible Netflow Not working in Cisco 4506-E switch
HCL Support
Hi Team,
We are unable to configure the flow-export in Cisco catalyst 4506-E switch. Please find the IOS & hardware details.
bootflash:cat4500e-universalk9.SPA.03.04.04.SG.151-2.SG4.bin
WS-X45-SUP7L-E
Chassis Type : WS-C4506-E
License- Entservices
This command also not working "Show ip flow export".
Please help on this regards.
Mark Malone
you could try alter it like below , I had issue's with flows on VSS and Nexus until I added the collect statements
Also try set your flow monitor under the interface as outbound as well as inbound
Also you have it applied to layer 2 interfaces its an ip ;layer 3 command put it under your SVI where the ips are not your trunks
flow record FLOW-RECORD
 description record to monitor network traffic
 match ipv4 tos
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 match interface output
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
 collect transport tcp flags
 collect counter bytes
 collect counter packets
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
jkilleda
Level 3
Level 3
Refer the configuration guide
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fnetflow/configuration/15-mt/fnf-15-mt-book.html
Enabling NetFlow on a per- interface basis is not supported on a Catalyst 4500 switch.
This example shows how to enable NetFlow globally:
Switch# configure terminal
Switch(config)# ip flow ingress
This example shows how to enable NetFlow with support for inferred fields:
Switch(config)# ip flow ingress infer-fields
