Power voltage for WS-C3750-48TS and ASA5525
ohforce55
Can anyone please tell me the power voltages for WS-C3750-48TS and ASA5525?
110v?
225v?
Than you.
Austin Sabio
Level 4
Level 4
I hope this helps. Good luck!
Cisco Catalyst 3750-48TS
AC Input Voltage and Frequency
• 100-240VAC, 0.6-1.2A, 50-60 Hz (Cisco Catalyst 3750-48TS)
Power Supply Rated Maximum
3750-48TS 75W 256 BTU/hour
Measured 100% Throughput Power Consumption
3750-48TS 66W 225 BTU/hour
Measured 5% Throughput Power Consumption
3750-48TS 60W 205 BTU/hour
Source: http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-series-switches/product_data_sheet0900aecd80371991.html
Cisco ASA 5525
Power
Input (per Power Supply)
AC range line voltage
100 to 240 volts alternating current (VAC)
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
AC normal line voltage
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
AC current
4.85A
4.85A
4.85A
5A, 100 to 120V
2.5A, 200 to 240V
5A, 100 to 120V
2.5A, 200 to 240V
AC frequency
50/60 Hz
50/60 Hz
50/60 Hz
50/60 Hz
50/60 Hz
Dual-power supplies
None
None
None
Yes
Yes
DC domestic line voltage
-40.5 to 56 volts direct current (VDC)
(-48 VDC nominal)
-40.5 to 56 VDC
(-48 VDC nominal)
-40.5 to 56 VDC
(-48 VDC nominal)
-40.5 to 56 VDC
(-48 VDC nominal)
-40.5 to 56 VDC
(-48 VDC nominal)
DC international line voltage
-55 to -72 VDC
(-60 VDC nominal)
-55 to -72 VDC
(-60 VDC nominal)
-55 to -72 VDC
(-60 VDC nominal)
-55 to -72 VDC
(-60 VDC nominal)
-55 to -72 VDC
(-60 VDC nominal)
DC current
15A (maximum input)
15A (maximum input)
15A (maximum input)
15A (maximum input)
15A (maximum input)
Source: http://www.cisco.com/c/en/us/products/collateral/security/asa-5500-x-series-next-generation-firewalls/data-sheet-c78-729807.html
Austin Sabio
Level 4
Level 4
Cisco ASA 5525
Power
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
100 to 240 VAC
AC current
4.85A
4.85A
4.85A
5A, 100 to 120V
2.5A, 200 to 240V
5A, 100 to 120V
2.5A, 200 to 240V
AC frequency
50/60 Hz
50/60 Hz
50/60 Hz
50/60 Hz
50/60 Hz
Dual-power supplies
None
None
None
Yes
Yes
(-48 VDC nominal)
-40.5 to 56 VDC
(-48 VDC nominal)
-40.5 to 56 VDC
(-48 VDC nominal)
-40.5 to 56 VDC
(-48 VDC nominal)
-40.5 to 56 VDC
(-48 VDC nominal)
-55 to -72 VDC
(-60 VDC nominal)
-55 to -72 VDC
(-60 VDC nominal)
-55 to -72 VDC
(-60 VDC nominal)
-55 to -72 VDC
(-60 VDC nominal)
-55 to -72 VDC
(-60 VDC nominal)
DC current
15A (maximum input)
15A (maximum input)
15A (maximum input)
15A (maximum input)
15A (maximum input)
