07-21-2019 03:28 AM
Hello !
I don't know if this is the right category for my question, so please pardon if not !
I have a 3750x switch running and one powersupply has a fault !
I dont't have the right PS to change, instead I want to replace it with a PS from a 3850x !
They look the same but have different Model-Numbers !
3850x PWR-C1-350AC/2
3750x C3KX-PWR-350AC
My question:
Is it possible to do so or would that effect an issue ?
Thank you for your help !
Solved! Go to Solution.
07-21-2019 04:09 AM
07-21-2019 04:09 AM
07-23-2019 11:07 AM
