04-01-2011 07:51 PM - edited 03-06-2019 04:24 PM
Hi everybody.
i was reading about ppp chap.
My book shows a following topology with debug output.
d
R1 s0------------------------------s0 R2
R1
encapsulation ppp
ppp authentication chap
username R2 password cisco
Similar config on R2 as well
Let just focus on R1 for simplicity.
Based on following link, Following will occur
http://en.wikipedia.org/wiki/Challenge-handshake_authentication_protocol
R 1 sends the challenge to R2
R2 receives the challenge and combines the challenge and password ' cisco" and compute hash value
R2 sends the hash value as a response to R1
R1 receives the response ,R1 then computes hash value on challenge and password and see if it matches.
If matches, R1 has successfully authenticates the R2.
But my book shows the following for the above described topology
Again focusing on R1
CHAP 😮 CHALLENGE ID 16 LEN 23 FROM R1
CHAP: RESPONSE ID 16 LEN 23 FROM R2
PPP: SENT LOGIN REQUEST
PPP" RECEIVED LOGIN RESPONSE PASS.
My confusion is since R2 has already been authenticated, then why does R1 send " login request to R2?
I also performed the same scenario using GNS3, creating a topology, R1 s0-------s0 R2
When i issued the debug ppp, on R1, i still get the same output where R1 sends a login request to R2 though R2 has already been authenticated by R1.
Thanks and have a great weekend.
Solved! Go to Solution.
04-02-2011 01:58 AM
Hello Sarah,
good point
our usual configuration actually performs a mutual authentication:
R2 authenticates with R1but also R1 authenticates with R2
there are modifiers for this by adding the option callin at ther end of ppp authentication command
There is also another aspect of PPP authentication:
if you issue a
show users
you see the PPP session listed among the sessions
so it is like one router logs in the other one using his hostame as username, and viceversa.
you can demonstrate this because you may be able to telnet to R1 using a vty using R2/cisco account.
(if you have login local under line vty)
Hope to help
Giuseppe
04-02-2011 01:58 AM
Hello Sarah,
good point
if you issue a
show users
Hope to help
Giuseppe
