PPPoE on 1711 and Webpages Not Loading
niall-wilkins
I have configured my 1711 for PPPoE and I am having an issue where some webpages wont load and where somepages will load but the images dont show up. For example I can bring this forum site up. I have tried using different computers but the pages dont come up. As soon as I remove the 1711 and go back to my 506E or linksys router for pppoe everything is fine. I have tried changing the inter face settings from auto-duplex and auto speed to speed 10 and half duplex but the same issue occurs. I have even tried different DNS servers. Has anyone come across this before? or heard of this? Here is my config:
Building configuration...
Current configuration : 1349 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
hidekeys
interface FastEthernet0
no ip address
speed 10
half-duplex
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
switchport access vlan 20
interface Vlan1
no ip address
interface Vlan20
ip address 10.1.20.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp pap sent-username xxxxx password 0 xxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list NAT_ADDRESSES interface Dialer1 overload
ip access-list extended NAT_ADDRESSES
permit ip host 10.1.20.2 any
control-plane
line con 0
line aux 0
line vty 0 4
end
Mark Yeates
Level 7
Level 7
Niall,
Try adding the "ip tcp adjust-mss 1380" command under Vlan 20. This is a common issue with PPPoE
connections.
HTH,
Mark
Mark Yeates
Level 7
Level 7
Niall,
connections.
HTH,
Mark
