pptp to ipsec
carl_townshend
Hi all, can anyone tell me the difference between these? is pptp used on windows server for vpn and is now old technology?
spremkumar
Level 9
Level 9
PPTP server can be configured on a router too and you need to have PPTP client which comes by default in windows .You just need to enable the pptp client on your windows client the very similar way you configure your dial up (PSTN) configuration.
But with ipsec vpn client u need to have vpn client software installed on the client pc to establish the vpn connectivity between ur client and the remote server.
regds
can anyone tell me the security defferences in these ?
