preferred_if_name_match: preferred interface 'vlan' of illegal syntax
will.cullen
Has any one seen this message before ?, it's from a 6509
Somasundaram Jayaraman
I believe there should be a configuration like "vtp interface vlan only" in the running config.
changing this to "vtp interface only" will fix the issue.
Let me know if you have any further questions
Cheers,
Somu
Rate helpful posts.
Cheers,
Somu
Rate helpful posts.
We had to open up a TAC case but you were spot on, Thank you and have rated the post.
