Printing Cisco documents
fsebera
Level 4
Level 4
Please accept my apology for posting this question here but I cannot locate the information needed anywhere else.
We  downloaded the Cisco support and CLI configuration documents for  routers, switches and firewalls (.pdf files) and now want to print these  manuals in hard copy. Our printing department informed us that due to  the copyright in the documents they are unable to print the documents. We only want a single copy and we do not plan on selling or modifying these documents, we need the documents for our own internal use - you know, to do our job.
Can ANYONE (especially a Cisco representive) help us (our printing department).
Thank you
Frank
2 Accepted Solutions
burleyman
Level 8
Level 8
Yes you can as long as you are not selling them
Check this link...
http://www.cisco.com/web/about/ac50/ac47/cisco_copyright_program.html
Hope that helps
Mike
No problem glad to help.
I noticed you post in the documents are as well. If you could mark that as solved to it would help others if they are looking for the same question.
Mike
5 Replies 5
burleyman
Level 8
Level 8
Check this link...
Hope that helps
Mike
Hey Mike,
Thanks for the quick and excellent response!
Now I just hope the printing folks can comprehend English.
Frank
Mike
Thanks for the reminder.
I do not normally ask the same question in multiple forums and do not recommend this practice for anyone but I was not getting any response in the original posting forum.
I thought a Cisco employee would have offered something useful, earlier.
Thanks again
Frank
No problem..... I will do anything for ratings....
Mike
