Multicast troubleshooting assistance
branfarm1
Level 4
Level 4
I am attempting to troubleshoot a multicast problem and I'm at a dead end.  I have a host that needs to join a particular group, but when the host joins, no data ever flows.  On the router (6506 w/Sup 720), I see a *,G entry, but no S,G.   I've also put a sniffer on the line between my router and the upstream router and I see PIM messages being exchanged, but I don't see any PIM register messages at the time I first join the group.  I've included my config items below, as well as a number of show commands:
interface Vlan2668
ip address 142.201.179.14 255.255.255.252
ip pim sparse-mode
load-interval 30
ip pim rp-address 142.201.52.45 36
Standard IP access list 36
    10 permit 233.102.209.0, wildcard bits 0.0.0.255 (33383 matches)
Group: 233.102.209.129, RP: 142.201.52.45, v2, uptime 00:32:09, expires never
Group: 233.102.209.130, RP: 142.201.52.45, v2, uptime 00:00:13, expires never
Group: 233.102.209.131, RP: 142.201.52.45, v2, uptime 05:48:26, expires never
Group: 233.102.209.131, RP: 142.201.52.45, v2, uptime 05:48:28, expires never
ip route 142.201.52.45 255.255.255.255 142.201.179.13
ip mroute 142.201.219.0 255.255.255.0 142.201.179.13
sh ip mroute 233.102.209.129
(*, 233.102.209.129), 00:33:36/00:02:17, RP 142.201.52.45, flags: SJC
  Incoming interface: Vlan2668, RPF nbr 142.201.179.13, Partial-SC
  Outgoing interface list:
    Vlan2, Forward/Sparse-Dense, 00:33:36/00:02:17, H
sh ip mroute 233.102.209.129 count
IP Multicast Statistics
200 routes using 128282 bytes of memory
104 groups, 0.92 average sources per group
Forwarding Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Group: 233.102.209.129, Source count: 0, Packets forwarded: 0, Packets received: 0
sh ip pim neighbor vlan2668
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
      P - Proxy Capable, S - State Refresh Capable, G - GenID Capable
Neighbor          Interface                Uptime/Expires    Ver   DR
Address                                                            Prio/Mode
142.201.179.13    Vlan2668                 2w0d/00:01:34     v2    1 / S P G
sh ip pim interface vlan2668
Address          Interface                Ver/   Nbr    Query  DR     DR
                                          Mode   Count  Intvl  Prior
142.201.179.14   Vlan2668                 v2/S   1      30     1      142.201.179.14
sh ip igmp membership 233.102.209.129
Flags: A  - aggregate, T - tracked
       L  - Local, S - static, V - virtual, R - Reported through v3
       I - v3lite, U - Urd, M - SSM (S,G) channel
       1,2,3 - The version of IGMP, the group is in
Channel/Group-Flags:
       / - Filtering entry (Exclude mode (S,G), Include mode (G))
Reporter:
       <mac-or-ip-address> - last reporter if group is not explicitly tracked
       <n>/<m>      - <n> reporter in include mode, <m> reporter in exclude
Channel/Group                  Reporter        Uptime   Exp.  Flags  Interface
*,233.102.209.129              10.8.0.19       00:36:45 02:39 3A     Vl2
Thanks for your help on this.   As a side note -- I have a lot of other multicast sources, receivers off of this switch, and all of them seem to work fine.  It's only these particular groups.  Also, if I add the ip igmp join-group command to the Vlan2668 interface, the data flows.  So something is wrong with the join process somewhere, but I'm not able to recognise it yet.
Brandon
plumbis
Level 7
Level 7
A followup from TAC-
The control plane looks correct here. Since a static-join makes the flow work we know that L2 multicast is working at the upstream device.
The captures we looked at after clearing the mroute indicate that the PIM join is being sent as expected. Sounds like an issue with the upstream device for L3 multicast.
-Pete
