Prioritizing network traffic
anishkmr0071
Frequent Visitor
Frequent Visitor
hi everyone,
can anyone help me in below configuration.
i want to prioritize my network, switch has to pick 1st priority as internal lan. following are the priorities. can anybody explain this.
Priority 1:  LAN (10.x.x.x)
Priority 2: network2- vlan2 (192.168.40.0)
Priority 3: network3 – vlan3 (192.168.60.0)
Priority 4: network4 – vlan4 (192.168.50.0)
thankyou,
6 Replies 6
Georg Pauwen
The solution depends on what device/platform you want to configure this on, and the IOS version.
Post the output of 'show version' of the device...
want to configure on a switch. it's a cisco SG-200 smart switch. doesn't have any cli. is there a way to configure on them?
thank you,
I think in the QoS Properties page of the switch, you can assign a DSCP value to each port. The DSCP values are mapped to one of the four queues. By default:
DSCP 14 --> maps to queue 1
DSCP 22 --> maps to queue 2
DSCP 38 --> maps to queue 3
DSCP 46 --> maps to queue 4
DSCP 14 and queue 1 are the lowest priority, DSCP 46 and queue 4 the highest. If you map your ports to these values, you should be able to achieve your traffic prioritization...
For your reference, please find attached the user guide:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/administration_guide/Cisco_200Sx_v1_4_AG.pdf
but, how can i assign those ip range to this queues?
I don't think you can. The SG200 has very limited options and is not a full IOS device.
For your reference, attached the CLI commands available:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf200e/command_line_reference/OL-22850.pdf
thank you
