Prioritizing UDP over TCP using QoS
ashleyreed4218
Level 2
Level 2
Hello All,
I'm trying to prioritize UDP traffic over TCP traffic for a WAN overseas. I've decided to go with the access-list option to prioritize UDP. The commands I've used so far are:
class-map match-all UDP
match access-group 101
class-map match-all tcp
match access-group 102
policy-map UDP-THEN-TCP
class UDP
  set ip precedence 1
However, I am unable to do the following:
class UDP
    priority percent 30  ---> my 3560 doesn't give me this option, why?
These are my actual commands:
3560X(config)#poli
3560X(config)#policy-map UDP-THEN-TCP
3560X(config-pmap)#cl
3560X(config-pmap)#class UDP
3560X(config-pmap-c)#prir
% Invalid input detected at '^' marker.
3560X(config-pmap-c)#?
QoS policy-map class configuration commands:
  exit            Exit from QoS class action configuration mode
  no              Negate or set default values of a command
  police          Police
  service-policy  Configure QoS Service Policy
  set             Set QoS values
  trust           Set trust value for the class
  <cr>
Any suggestions?
Thank you in advance!
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Any suggestions?
Yes, read your IOS version's reference manual and configuration guide's chapter on QoS.
You appear to be trying to use "router" QoS.  3560-X doesn't support egress polices like a router does.
Joseph W. Doherty
Disclaimer
Posting
Any suggestions?
