Private VLAN basic question
gautamzone
Level 6
Level 6
Hi friends,
I have a basic question on Communication between two different community vlans.
If i have a switch called S with two community vlans viz. A and B and two promiscious ports connecting to a non-Cisco switch (that does not understand private vlans). Can this non-Cisco switch achieve communication between two distint community vlans? Or do i need only a Layer 3 device to achieve inter-community vlan communication?
Thanks a lot
Gautam
misramanish
Level 2
Level 2
Hi Gautam,
While all the switches (Cisco or not) can pass traffic to each other for their respective VLAN's, to my knowledge you will require a Layer 3 device to pass data between VLANs, whether Cisco or otherwise.
Hope this helps!
Giuseppe Larosa
Hello Gautam,
if the non Cisco switch is a L2 only switch being the community vlans different vlan numbers it will not create a backdoor between them: they are separate broadcast domains.
If it has L3 capabilities it could provide a way to an attacker to get access from one community vlan to the other.
However, a L2 switch has at least a management IP avoid to have it in the private vlans' IP subnet.
If it allows inter-vlan bridging like it is possible on a C3550 or other switch it can be configured to make a bridge so defeating the private Vlans deployment.
If someone connects with a crossover cable one port in vlan x and one port in vlan y on the L2 standard switch the same result is achieved of defeating the private vlans.
Being vlan x and y the two community vlans.
So disable all the unused ports and put them on a non routed vlan.
Private Vlans try to segment a single IP subnet in multiple broadcast domains under the control of the switch.
A l3 device cannot have overlapping ip addresses on different L3 interfaces.
Hope to help
Giuseppe
Hi Giuseppe,
I have one mroe question, if we configure separte private vlan as community VLAN for example 346 and 355 and connect two differnt devices to a primary vlan 309 which is Layer vlan, will vlan 346 and vlan 355 will be able to communicate to each other.
As i was goning throug the CISCO doc and came across the following line which says community vlan is doing isolation at layer 2 but allow communication at layer 2. This statement is very ambigious to me. . As without layer 2 information how there will be communication at layer 3.
Although private VLANs provide host isolation at Layer 2, hosts can communicate with each other at Layer 3.
Please suggest
Sushant
