Private-VLAN Problem
cscomuhammad
Hello everyone
I have problem running Private VLAN using ASA Service module and Catalyst 6500 series switch.
Here is my scenario.
Running Private VLAN using VTP version 3 on cisco 6500 as a VTP server and creating VLANs as mentioned below
 SW 6500:
firewall multiple-vlan-interfaces
firewall switch 1 module 1 vlan-group 1
firewall switch 2 module 1 vlan-group 1
firewall vlan-group 1  2-1001
vlan 128
private-vlan  primary
private-vlan  association 129,130
 vlan 130
private-vlan  comunity
vlan 129
private-vlan  isolated
And configuring the interface connected to the host on the access switch
Access Switch:
interface GigabitEthernet2/0/1
 switchport private-vlan host-association 128 129
 switchport mode private-vlan host
 When I create primary SVI and then map the secondary VLANS on cisco 6500 everything is ok but the problem starts when I create interface VLAN 128 on ASASM, it seems they have no connectivity.
Is there anyone know where is my mistake or have any solution to this problem?
Does 6500 SVI see ASA SVI when the corresponding vlan is not part of private vlan? I mean you have configured ASA correctly with security level and ICMP is allowed to test?
yes, I have multiple SVI on ASA and they are working properly. the problem starts when I want to use private VLAN (no connectivity)
​therefor, I've checked arp cache on the host and the ASA but nothing to display.
I know ASA is working properly, is there any other configuration on 6500 that I haven't done ?​
it looks good to me. Here an example. Connect a host to one of the 6500 port and try to ping both 6500 and firewall.
6500
vlan 11
vlan 12
vlan 13
  private-vlan community
vlan 14
vlan 11
  private-vlan association 12-14
nterface Vlan11
 ip address 10.2.1.1 255.255.255.0
 private-vlan mapping 12-14
Firewal
interface Vlan11
 nameif inside
 security-level 100
 ip address 10.2.1.2 255.255.255.0
allow icmp( something like that)
icmp permit 10.2.1.0 255.255.255.0 inside
Hope it helps,
Masoud
